Question about Kenmore 15516 Mechanical Sewing Machine
Kenmore sewing machine 385.1960180, problem with needle centering
Upon replacing needle, it's out of adjustment as it strikes the plate and the foot. Cannot zigzag stitch as the needle strikes the plate and foot. The needle clamp seems to too jiggly. Could something be broken on it. And the bar to which the needle is attached doesn't center the needle correctly. It's off to the left causing the needle to hit the foot. I've used the correct instructions to center it, but it still is off.
    Problem Solver:
  • 9 Answers
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
Singer Quantum XL-1 the needle strikes the left side of the presser foot/needle plate in the zig-zag mode. How do I correct it. I have a new needle.
have you got the correct plate installed for zigzag sewing
it is the needle that jumps side to side and if you are using a single hole plate that will cause the problem
Oct 30, 2017 | Singer Sewing Machines
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
Using a universal pleating foot, starts out fine then I break a needle, 5 so far. It hist the pressure plate. Using a straight stitch, needle is centered. Bobbin is treaded correctly. Needle is straight at...
Sounds like the needle is hitting the moving part of the pleater once you get going, getting bent then striking the needle plate too.
Its not going to do the machine any good if you keep striking it with the needle as you'll end up putting the timing out.
As the pleater is a generic type it is probably best to stop trying to use it on your machine.
Jun 26, 2011 | Brother XL-2600I
I have a Kenmore model 1690. The needle when it goes down does not hit the hole in the foot plate. It comes down too far to the left of the opening, making it impossible to use the machine. I have...
This machine, when you have it on straight stitch, will sew with the needle to the left. If it's hitting the pressure foot, you may have the wrong pressure foot on the machine. If it's hitting the needle plate when you have the pressure foot removed, it's possible you have set for zig zag and you have a straight stitch needle plate on the machine. I believe this machine came with 2 needle plates. One for straight stitch, and another for zig zag.
May 03, 2011 | Kenmore Sewing Machines
My kenmore sewing machine needle is coming down on presser foot.
Check the needle to make sure it is inserted with the flat side of the shaft toward the back of the machine.
Also, check to be sure the needle is not bent.
Remove the presser foot and see if the needle clears the opening in the needle plate and pulls up the bobbin thread.
If all of the above checks out, switch to a presser foot with a wider opening.
If not, the machine needs to be serviced as it may be the timing has to be adjusted.
Whenever you pick up a machine that has been serviced, try it out before taking it home.
Mar 17, 2010 | Sewing Machines
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Keep breaking needles
Here are some solutions to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Check your needle plate and make sure it's securely in position.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
Hope this helps.
Sep 20, 2009 | Singer 132QRFB Mechanical Sewing Machine
My PE 100 keeps breaking needles, they are striking something during use.
    Here are some things to try.
    * Your broken needles may have been too thin for your fabric. Make sure your replacement needle
    If this doesn’t seem to be the problem
    Make sure it’s attached securely.
    Make sure it's securely in position.
    I hope this helps.
Sep 11, 2009 | Brother Sewing Machines
Kenmore sewing machine older model 1345381
hi! there wind thread on bobbins winder 4 times by your hand rotate clockwise,insert in shaft bobiins winder on top of your machine near hand wheel push latch to engage loop thread on disc winder tension start your machine on pedal foot automatically winder disengage if already filled up of thead pull this winder and insert to bobbins casing insert thread to slot and pull out winder 6411c87.jpgshould rotate clockwise as shown.insert on shuttle hook casing and close cover needle plate.next thread your upper
97b52e8.jpgthreading tension as shown on red threading from spool pull threading and loop to dial tension threading and insert thread to lever needle and to needle hole tip. pull tread under the needle foot and feeder tooth.rotate hand wheel counter clockwise to hook up thread bobbibs and appear at top of needle plate,teo thread shoul appear,set dial tension to # 3 and stich to # 8 range to # 12 depend on fabric and layer of fabrics and set on straight stich sewing,let needle on upper position insert fabric for trial sewiing.put down foot needle lever. manually by hand rotate for assurance needle is free to sew if obtruction on loop bobbins thread occurs adjust all tension gradually then try again until free from sewing w/o problem star sewing.
Aug 08, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing with walking foot
Take the needle out and run the machine for a while with the walking foot fitted. Refit the needle and try again but only turn the machine over by hand to see if the problem has cleared. If no luck it sounds like the walking foot timing needs adjusting.
Apr 05, 2008 | Janome 8080 Computerized Sewing Machine
Kenmore 15516 Mechanical Sewing Machine Logo
374 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
