Question about RCA HD61LPW42 61" Rear Projection HDTV
Cycling green line
There's a green line the cycles from the bottom to the top of the TV. This only happens when cable's on, non on any of the other functions. Any ideas?
  • 41 Answers
It could be one of a few problems if its only happening with cable.
1.if you have a cable amplifier near your main splitter it could be bad
2.your cable box is bad
3.whatever connection you are using could be bad. change the cable/cables first. if that doesn't fix it change the connections to a different input. if that works you probably have a bad input.
Posted on Mar 29, 2009
On my e-motion tv when I switch it on and go onto did it says no signal....help please
Why does my TV say no signal? If your HDTV or Standard TV displays a "No Signal" error message, it may be due to one of the following issues:
  1. Determine how many TV's are affected.
    • If it is one TV, continue to step two.
    • If multiple or all TV's are affected, continue to step five.
  2. Ensure that your HDTV is on the same source/input as your MTS Ultimate TV service.
    1. Press the TV button on your MTS Ultimate TV remote control.
    2. Press the TV/Video button.
    3. Wait 10 seconds.
    4. Repeat steps b and c continually to cycle through all the available source/inputs on your TV until the correct source/input is selected. (ie. HDMI 1, HDMI 2, Component 1, Component 2, etc.) On standard TV's (non HDTV), you may have only 2 choices, TV or Video.
  3. If the source is correct from step two:
    1. Unplug the HDMI cable from your MTS Ultimate TV Set-top Box.
    2. Wait 30 seconds.
    3. Plug the HDMI cable back in.
    4. Wait for the signal to initialize.
    5. Make sure all cables connected on the set-top box and your TV are secure.
  4. If the problem persists:
    1. Unplug the power cable from the back of the MTS set-top box.
    2. Wait 60 seconds.
    3. Plug the MTS set-top box back in.
  5. If you are still experiencing a problem:
    1. Make sure ALL Ethernet and/or Coax cables are securely in place.
    2. Unplug the power from the MTS box labeled 2Wire or Pace as well as the affected set-top boxes.
    3. Wait 60 seconds.
    4. Plug the power back into the MTS box labeled 2Wire or Pace.
    5. Wait for the broadband light to turn a solid green colour.
    6. Plug the power back into the affected set-top boxes.
    7. Wait for the signal to initialize.
Good Luck
Feb 24, 2015 | Televison & Video
Green line around the screen
Look for any magnetic materials around that area. Try changing the input device to something you know works for sure.
Jul 22, 2012 | Samsun PN43E450 43" 720p Plasma TV - 16:9...
My super nintendo has green lines that keep running down the tv screen from top to bottom. Everything else works fine and you can still play but the green lines are really annoying.
Well the reson why there are lines in it becuase its starting to wear out the connections or if you are using the av cables or an rf switch it might need a new av cable or and rf switch then.
Jun 23, 2011 | Nintendo Super NES Console
My LG Plasma 42PC3D turns on and off repeatedly. I turn on my FIOS set top box first and than the TV and it turns on and off repeatedly (front bottom display goes red and green, red and green repeatedly)....
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Sep 24, 2010 | LG 42PC3D 42 in. Plasma Television
Red & Green lines rolling from the bottom to the top
You could have a ground loop problem. To test plug DVR and TV into same outlet.
Dec 27, 2008 | Televison & Video
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
Water leaks out of the bottom when running cycles
This problem is usually associated with the drain line or drain pump. Need to check while in this mode.
Mar 27, 2008 | Frigidaire FEX831CS Top Load Stacked...
DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Feb 08, 2008 | Samsung DLP HL-P5663W 56" TV
Phomtom lines
It could be #1 a ground loop in the cable line....#2 bad caps in the power supply.....#Or a loose LVDS cable going to the light engine.
Jan 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
RCA HD61LPW42 61" Rear Projection HDTV Logo
29 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
