Question about T-Mobile Sidekick II
It freezez a loy
When i turned on the sidekick 3 and press the menu button the sidekick 3 freezez what do i do
    Problem Solver:
  • 9 Answers
The button probley got wet or if not it has a bad fuse and cnt work through so u have to get it fixed
Posted on Jun 07, 2009
My sidekick wont get service
Maybe it's because you're phone might off turned off and you didn't know. Because, if a sidekick turns off, normally when it comes back on everything is gone.
Oct 03, 2009 | T-Mobile Sidekick II
Tmobile sidekick 3
try pressing the button that lookes like :
the three lines.. and l at the same time, but my sidekick is unlocked so im not sure if it will work wiht yours.
Jun 27, 2009 | T-Mobile Sidekick II
I forget my privacy code
Well the easiest way is:
1: press menu and jump to enter emergency call
2: press and hold down menu button and while holding menu down,
press jump and back simultanously.you should enter the jump screen.
the end.
After u do that, if u wanna use the phone your gonna have to erase all the settings and do a master reset. Your going to need a tmobile sim card, and sidekick log in info to use the phone, which you should be able to get the login info by calling a T-Mobile CS agent.
Heres how u erase the flash and login info:
This is for the sidekick 2. It MAY work.
1) Remove your sim card
2) From the jump screen: Menu -> Settings -> System Info
3) Press Menu+Shift+X Select OK to clear the flash.
4) Press Menu+Shift+R Select OK to clear the login information.
5) Perform a hard reset now. This will reboot the device.
To perform a hard reset:
SK2 - Press the power button and reset button at the same time. Unit will vibrate when reset. You can use a paper clip or similiar to hit the reset button located behind the screen.
Good luck, hope that helped!
Jun 22, 2009 | T-Mobile Sidekick® 3 Cellular Phone
I forgot my 3# code for my sidekick lx
this is for the lx
put ur fone on the lock screen and press teh call button twice and u should see three emergency call numbers here u push menue shift and q and accept the defalt changes and this should let u in free and clear
this is for the sidekick 3 press menue and home button on the left hand side u should see three emergency call numbers here u push menue shift and q and accept the defalt changes and this should let u in free and clear
Mar 29, 2009 | Sharp Sidekick LX Smartphone
Locking my phone back
PRESS THE MENU BUTTON GO TO SETTINGS THEN ROLL DOWN TO KEYGUARD AND SECURITY GO DOWN TO TURN ON PRIVACY LOCK
IF THIS WAS HEPLFUL PLEASE LEAVE A RATING
Feb 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
when it turns on it will say "Waiting for activation," when it says this press the menu, or top left black button and "L" hold for about 3 seconds.
Sep 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick lx
while your on the privacy lock you press the call button 2 times, then the emergency call shows up , once that shows up yu press the menu button (the top left button w. tha 3 lines) while holding shift & Q .
& a message pops up saying if you want to reset to factory settings n yu juss press reset & it takes outt tha code n all tha things in the sidekick ..
your welcome :]
May 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
SIDEKICK 3
1. Insert your non-TMobile sim card 2. The phone display says "Enter the code". 3. On your Sidkick, press the "X" button. 4. You will see the menu. 5. Choose the left-up angle button. 6. Choose "setting"--->"network"--->"scan and select manually". 7. The phone will search for your network. 8. When your Sidekick finds your network, you can use the phone to make calls
Jan 31, 2008 | T-Mobile Sidekick II
Sidekick 3
Want to clear out info on your Sidekick info (ie: to sell yours)?
SK3 - remove the battery while the device is on.
6) Call your carrier and ask them to detach your device IMEI from the username locked in. Once that is done, hard reset without your SIM card inserted.
You're done.
http://shop.sidekickskin.net/Sidekick-Tips-Tricks
Jan 02, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Unlock Code for Sidekick 3
ok the way to do it this jus lets u use text and calls i got cingular and i used my sidekick to txt and call here wat u gotta do
1. out sim card in
2. start phone
it will tell u sim card locked it needs special code(the code u get to pay for) juys exit outta that get to the main menu
3.hit the top letf menu button and go all the way down to sim center if u dont allready have a sim pin then enter a new one if u have one change it then ur phone should go from the big X to some bars and a hollow phone icon after you do that hit the menu button again and go to network options then go down and hit (SCAN AND SELECT MANULLY) then chose what ever carrier you have i have at&t so i chose it after a few seconds the hollowed out phone icone should be colored in and u can now text and call
Dec 03, 2007 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick II Logo
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
