Question about Clerc 807 Wrist Watch
Clerc watch.. could someone plese tell me if the rubies in these watches are the exact same? clerc watch807r and clerc watch806b-r? thanks
Came across a vintage minerva stop watch can you help price it.
ebay lists 7 search results between £30 - £190 I guess it depends on the exact age and model and providence of the particular watch. Only a valuation by someone who is familiar with this market would be able to tell you.
(search on vintage Minerva stopwatch)
12.February.2015
Feb 12, 2015 | Vintage Watches
I cam across a rare minerva stopwatch im tryint to price it can you help
12.February.2015
Feb 12, 2015 | Watches
Omega Seamaster
This is probably a hand adjustment issue. The hands sit on the center post, or pinion. If they get bumped or shaken they can get out of place. You will need to go to a watch marker or tech to get an exact cause of problem. Try Fastfix or a Mom and Pop store with someone on staff who can look at it.
Apr 23, 2013 | Watches
I have a 18k gents gold Rewel 17 RUBIS incabloc watch that isnt working,i took it to a good jewellers and they sent it off for an estimate for repair,but it came back with advice to take it to an...
The incabloc movement is not too expensive but it sounds like your watch is! I am not sure the movements are available for the older watches anymore, your watch will need the right measurements, so if you take it to a watchmaker they have many older parts and may have a watch movement to fit it! The picture in my profile is of a very expensive 6 ounce gold ladies watch with an incabloc movement. The watch was thought to be from Europe somewhere , it was sold for its beauty and the movement itself did not work! Hope this helps explain your problem a little better! thank you!
Sep 21, 2011 | Watches
Just bought a vintage Citizen Super Crystal Date stainless steel watch. Serial No. on back is 00625090. Can you provide the approximate or exact date of production? Thank you.
We cannot tell you from the serial number what the model watch you bought is . But you can call Citizen watch 800 321 1023 extension 4234 and give them the serial and they will be able to tell you the model and year the watch was produced.
Oct 14, 2010 | Watches
Hi there hope you can assist me. My first question to you, and thanks lots I have a Jules Jurgensen watch, and it arrived brand new without a battery. 1) Does a battery for a 7837BR normally...
All watches should arrive with battery fitted. As now there are too many variations of watch movements, it's impossible to tell exact battery code without seeing the watch. Nearest watch repair shop will be able to tell you that.
Jul 30, 2010 | Jules Jurgensen Watches
Hi one of the pink crystals around the face of the watch came off and is missing.do i send it tou for repair.thank you roberta
mcdevito75 here, Hello Roberta, You may have too, but first look for a small watch repair shop in your area and see if they can match it up or order the crystal part for you then install it.
Jul 07, 2010 | Clerc BJ2086 e by Betsey Johnson Watch...
Seconds hand not moving
The roles haven't been reversed. The seconds hand for normal timekeeping is the small one and the chronograph timer seconds hand is the large one. The reason for that is that it is much easier to determine the precise second with the larger hand. It working exactly as it should. If you like having the large second hand moving all the time you will not hurt the watch by leaving it running. All chronographs work this way. Nice watch - wear it well!
Apr 29, 2010 | Swiss Army Wenger Commando 70725 Wrist...
Bulova 14k Solid Gold woman's watch. Swiss 17 Jewel unadjusted Bulova Watch co. 6AH S/F dial with 3XS under the S Watch Case: inside on back-Bulova 14K solid gold New York Watch band: Kreisler Quality USA...
This sort of information is only likely to be available from an authorised dealer.
If you go to the Boluva web site, you will be able to use their dealer locator to find the one nearest you.
Mar 17, 2010 | Bulova Ladies 14K Gold Collection Watch
Clerc 807 Wrist Watch Logo
120 people viewed this question
Top Clerc Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Clerc Watch Expert? Answer questions, earn points and help others
