Question about RIM BlackBerry Curve 8310 Smartphone
How do I forward calls from my Blackberry?
How do I forward calls on the Blackberry to another phone?
  • 564 Answers
Posted on Feb 20, 2009
  • Prem  Kumar
    Prem Kumar Feb 20, 2009
    • Under call settings seleting forwading.
    • then enter the number you wish to forward.
    • Then activate it.
    Note: You should activate call forwarding service from you service provider.
    Hope this Help, Please rate my response!! Thanks,
  • 20 Answers
Check the manual
Posted on Sep 08, 2009
2 Suggested Answers
  • 20 Answers
SOURCE: Call forwarding on my Blackberry
Check the manual
My blackberry wont forward calls ( i already set up the forward call settings)
Just check the message center number of your SIM card that you used if it is not change. Copy the message center number to the same SIM card.
Apr 04, 2013 | Nokia Cell Phones
Call forwarding on a panasonic dect 6.0 cordless phone through shaw to my blackberry
Setup your personal Shaw "My Account" ID & password.
Then, login to:
and click "features", and enable call-forwarding.
Type in the phone-number of your BlackBeery.
Sep 23, 2012 | Panasonic KX-T7453 Corded Phone
How do I cancel the call forwarding on blackberry curve
go in the menu
  1. options > phone options
  2. scroll down to call forwarding
  3. when in call forwarding
  4. then click never for forward calls
Sep 27, 2010 | RIM BlackBerry Curve 8310 Smartphone
Forwarding calls
You can forward calls from a landline. You will need to see if your landline service includes call forwarding. It's typically a code you punch in before dialing the number in which you want the calls forwarded to.
Hope this helps. Good luck!
Jul 31, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Blackberry 8700
i dont have a blackberry but try settings, call settings call forwarding and look in there
Jul 22, 2009 | RIM BlackBerry 8700c Cellular Phone
I have the same problem. Any ideas??
Hi, the setting is controlled by your mobile service provider. You will need to ring them and get them to extend the time which it will ring before going to your voicemail. Another option is to totally disable the voicemail function. On your blackberry, enter the phone screen, then press the blackberry logo button to open the menu then select options. Once in the options, select the call forwarding option. Change all settings to "do not forward". Please rate this solution if it helps. Thanks
Jun 08, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do I forward call on my blackberry?
Open BlackBerry Call Forwarding Options
To access your BlackBerry call forwarding options screen, click the green Send key and then open the menu options by clicking the BlackBerry Menu key. Scroll down and select Options.
You'll then be presented with a list of your BlackBerry's Phone Options, which include Call Forwarding. Click on this option and wait a few seconds for the call forwarding screen to populate.
Enter a New BlackBerry Call Forwarding Phone Number
Before you can forward incoming calls via BlackBerry, you first need to enter the number you want calls to be forwarded to.
On the main Call Forwarding options screen, click your BlackBerry Menu key and choose New Number. A dialogue box will then appear asking for the number to which your calls will be forwarded. Type in the 10 digits and click the trackball to save the number.
If you mistyped the new call forwarding number and you need to correct it you can click the BlackBerry Menu key on the main call forwarding screen, choose Edit Number, scroll to the number you wish to modify, click the trackball again and choose Edit from the available options. From there, you can make your desired corrections. To save the changes, simply click the trackball one more time. You'll then be returned to the Edit Forwarding Numbers screen. You can reach the main Call Forwarding option screen by clicking the BlackBerry Escape key once.
Enable BlackBerry Call Forwarding, Tweak Settings
On the main BlackBerry Call Forwarding screen, you have two options for call forwarding: 1) Forward All CallsForward Unanswered Calls. Below the latter option, you have three more choices: A) If Busy; B) If No Reply; and C) If Not Reachable.
By default, your device is set to Forward Unanswered Calls to your carrier's voice mail box in all instances.
BlackBerry Forward Unanswered Call Options
Forwarding every call that comes in to your device is simple; you just fill in the circle next to Forward All Calls and then specify the number to which you wish to direct calls from the corresponding drop-down menu. To save any changes you make, click the BlackBerry Escape key and confirm the changes when prompted.
Forwarding calls in specific situations is a bit different, but it's no more difficult. The first thing you want to do is ensure that the circle next to Forward Unanswered Calls is filled in. (Again, this circle will be filled by default unless you modified your settings.)
To forward only the calls that come in while you're already on the line, click on the If Busy option to open the drop-down menu and then choose the number to which you want to forward your BlackBerry calls. If that's the only call forwarding option you wish to modify, click the BlackBerry Escape key and confirm the change when prompted.
If you want to forward calls that come in while you're, say, in another room and away from the phone, change the number associated with the If No Reply option and save your changes.
If you want to receive calls when your BlackBerry is turned off or you're otherwise unreachable, modify the number settings next to the If Not Reachable option and again save your changes.
When BlackBerry call forwarding is enabled, you'll see a small icon, which looks very much like the missed call icon, appear on your BlackBerry home screen.
Finally, if you wish to return to your device's default settings, simply fill in the circle next to the Forward Unanswered Calls option and set the number for all three options (If Busy, If No Reply and If Not Reachable) to your wireless carrier's voice mail digits.
May 11, 2009 | Google Android
I have left my Blackberry at home and want to divert my phone number to my office phone
just call customer care, ask them to set up your call forwarding. *611 from your phone or 1-800-331-0500 from any line.
Dec 03, 2008 | AT&T Blackberry Curve 8300 Smartphone
Blackberry Curve 8310
You have to go to Phone options->Call Forwarding and you have option of forwarding all calls or if busy, if no answer or unreachable. and you can select the phone number where you want to divert the call
Jul 17, 2008 | RIM BlackBerry Curve 8310 Smartphone
RIM BlackBerry Curve 8310 Smartphone Logo
4,037 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
