Question about Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA
I have a thor electric drill. I am unable to remove the chuck on the drill. can you help?
    Problem Solver:
  • 12 Answers
Open up the old chuck all the way and there is a screw down in the middle of the chuck, unless it is missing. The screw is left-handed threads. Remove the screw. Take a large allen wrench. Tighten down in the old chuck. The chuck is right handed threads. Lay the tool down on its side. Take a hammer and hit the other end of the allen wrench several times until the chuck comes off (some of them are on very tight). If it doesn't come off, then spray WD-40 down inside the chuck and let it sit overnight or for a few hours and then try it again.
Don-www.toolsandmachinery.com
Posted on Feb 24, 2009
How do you remove the chuck from a 3/8 electric drill
Open up chuck for largest drill bit. Look inside and you will see a screw, remove the screw. Put a pair of vise grips on the stationary part of the drill chuck, which is the part of the chuck that the tightening tool goes into. The chuck is screwed onto left hand threads. Take a rubber mallet and hit the pair of vise grips clockwise sharply, to loosen chuck. You can now do what you planned on doing. GOOD LUCK FRIEND.
Feb 12, 2015 | Drills
The keyless chuck on my "PSB 5000 RE" electric drill has jamed up and cannot be used. Can it be replaced or is the whole electric drill a throw-away?
chucks are screwed to the drill by a left hand theaded screw. try to get the jaws open enough to access screw then replace with new keyed jacobs chuck. they are brill.
Aug 12, 2010 | Bosch Garden
Drill chuck removal
Look down into the chuck and you will see a screw. It must be removed so that the chuck can be pried off. It should be righthand(standard thread) lefty loosey. An impact driver is my favorite tool for removeing the screw, as you must not strip it or you will have to drill it out. Once the screw is removed, put the drill in a padded vise if one is available and do what is necessary to pop the chuck off. Something with enough width to span from the chuck to the drill body can be carefully driven between the two to break it loose.
Apr 04, 2010 | Dewalt 3/8" Electric Drill D21009
How do i remove the chuck from an dv 18 dl cordless drill
Most drills have the chuck secured with a screw. Twist the chuck to open jaws fully. Look into the chuck to find a screw head - it may be a straight, phillips, allen or other type blade to engage so that it may be loosened and removed.
If unable to remove the screw - it may have left-handed threads, so try turning the screw in the opposite direction.
I hope this helps!
Oct 26, 2009 | Drills
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
Chuck removal
First open the chuck jaws and remove the LH chuck retaining screw. After that find a bent handle allen wrench about the size of the chuck. Put the shorter end in the chuck and clamp down on it. Put chuck on a block of wood or workbench with the long end at about a 30 degree angle so you can hit it counterclockwise with a hammer. It might take a couple hits but it will come off.
Jan 01, 2009 | Makita 6304LR 1/2" Chuck Electric Drills
Hitachi cordless drill, removing chuck
Replacing the chuck on a drill is simple when you know the trick. I worked at a tool rental center while attending college and learned how to repair many tools. Open the chuck enough to remove the screw that you will see inside the chuck. It will most likely be reverse thread. The chuck is threaded on the shaft so just simply close the chuck on an allen socket and impact off with air or electric impact tool. If you do not have an impact tool close the chuck on-to the largest allen wrench that will fit into the chuck.(with the long part of the allen wrench projecting out) You will need to set the drill into a vise or strap to work-bench, then strike allen with hammer. Most chucks are removed with one quick impact of the hammer, counter clockwise. Do not squeese the drill too tightly with vise, we used a piece of leather to protect the drill. Good luck. Enjoy
Dec 16, 2008 | Hitachi NV45AB2S Coil Roofing Nailer
Keyless chuck removal
Yes you can use any kind if chuck as long as the thread that attachs it is the same size, look on line lots of tool stores sell them cheap.
Sep 22, 2008 | Makita HP1621FK 5/8" Hammer Drill Kit with...
Dewalt Heavy Duty Xrp 1/2" 18V Cordless Hammerdrill/Drill/Driver Kit DC925KA Logo
1,073 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
