Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Vertical lines of different colors have sound but no picture
Vertical lines of different colors no picture but have sound
You didn't mention the model and make :)
Posted on Feb 20, 2009
  • arnelgm Feb 20, 2009
    ok, if this is LCD direct view it could be the connector on the T-con board or the T-con board itself if not replace the main board :)) -arnel
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
No picture just vertcal colored lines and sound
What is the exact model number to your Poloroid TV?
Jul 12, 2012 | Televison & Video
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Dec 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
Mar 10, 2009 | Funai F42PDME 42 in. Plasma Television
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
140 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
