Question about Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 5 stack cd player
Hi guys,
i have a peuget 307 2002 model with the 5 stacker cd player. about two weeks ago i put in a few burnt cd's, all was well until today when it stopped playing!(sound stopped) the screen saids its still playing( by counting the seconds on each song) but no sound comes out.
when i flick to radio, the sound id fine it still works but cd's, nothing comes ut at all.
does anyone have the same problem or even better a solution?called peugoet they said it was going to cost $1,500 to fix. any othe ideas?
please help
finlay
  • seramjohnson May 15, 2009
    I have a similar problem. I bought the car back in march a 51 plate the cd player did not work. I bought one from ebay and had it put in by my local garage and it has been working well for a week but today I put in a cd that i burnt myself and it said it was playing but no sound and the same the radio is fine. I also can not get the cd's back out. The numbers from 1-5 are all flashing, so I think that it has broken again. Dont fancy going to a peugeot garage as it will cost a lot of money.
    New Friend:
  • 97 Answers
Hello hi ... umm first of all the cd player of that car has issues and its not only you who has faced it.
secondly rather than spending $1500 get a new stereo..
its the era of usb, aux and bluetooth now
Posted on Apr 20, 2017
5 Suggested Answers
SOURCE: Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Posted on Jan 23, 2008
SOURCE: peugeot 307 04 plate
just disconect leads on cd changer should reset
Posted on Dec 19, 2008
SOURCE: Peugeot 307
having same problem. faulty after disconection of battery
Posted on Oct 22, 2009
Warf135
  • 137 Answers
SOURCE: Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Posted on Apr 05, 2010
PEUGEOT 307 FUSE KEEPS BLOWING (abs faults, horn doesnt work)
i have a peugeot 307 number 8 fuse keeps blowing so i have to keep changing the 20 amp fuse please help me i am trying to find out what is causing this
Dec 07, 2012 | 2002 Peugeot 307
Peugeot 307 1.6i Hi rev low speed....
and 4000RPM at 90MPH is a problem??
Sep 23, 2012 | Peugeot 307 Cars & Trucks
My peugeot 307 2002 heater is not working
if it is just the heater motor they are not that bad to do
they are located in the passenger side under the dash (you may have to remove the glove box)
they are only held in by a few torx screws
Nov 16, 2009 | 2005 Peugeot 405
1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Jul 31, 2009 | Car Audio & Video
Peugeot 307
Jun 03, 2009 | Blaupunkt Car Audio & Video
Cd player will not play
Hi Guys,
Here`s the fix! Took out 6 cd stacker found out makers name, stripped it apart found out why it was`nt working, 1 broken part, unable to get part, so went to Garage Sale bought 6 cd stacker diggerent make $20.00 fit into car and it`s all good now, problem solved. THANKS ANYWAY. mc.
Mar 27, 2009 | Car Audio & Video
Flashing lights on cd changer, Peugeot 307!
There are a few variations of this model eg; IDCA09,IDCA04,Fiat & aftermarket units.As already stated these models do suffer from mechanism faults quite a lot.This is due mostly to the complexity of the mechanics.The flashing lights are a classic symptom of a jammed or broken part of the mechanism.They can however be repaired by certain car audio repair centres here in the UK.I'm afraid unless you know what you're doing then just by stripping the mechanism down is unlikely to cure the faults than can occur.
Feb 03, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd player
hi does it do anythig at all? does it flash?
Mark
Mar 21, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Blaupunkt IDC-A09 5-Disc CD Changer Logo
2,672 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
