Question about E-Machines M6811 Notebook
Shuts off in the middle of use for no reason
My lap top keeps shutting off while I'm in the middle of using it does not matter if it's plugged in or not and the fan runs really high right before it shuts off
  • 1 more comment
  • regle Feb 24, 2009
    shuts off in the middle of use for no reason"
  • Neonnicko Mar 21, 2009
    I too have a E-machines m6811 and for a while it worked fine. Now however the machine will turn on the fan at fullspeed and after about 2 seconds it shuts down. I have a temperature monitor program and the temperate was only at like 120 F, which is a normal temperature.
    Also, many other things are wrong with it such as:
    -Computer freezes when trying to read a CD (sometimes it reads DVD's)
    -Disk Defragmenter does not work and I get this message:
    "MMC cannot open the file C:\WINDOWS\system32/dfrg.msc."
    I also get this message for some programs(some of which do work):
    "This application has failed to start because MSCTF.dll was not found. Re-installing the application may fix this problem.
    Anyhow..I little while ago I checked the drive for errors and it seems to improve a little but it still has all these symptoms. I'll see if this solution works though.
  • fredtjr85 Apr 12, 2009
    basically the same problem as grasshopperb's. It shuts off without warning. I took it apart, cleaned it, and I even changed the CPU fan with some kind of thermal paste bonding the fan and the CPU. It has not improve the situation. I have been reading online that there are quite a few of these cases with the e-machines M6811 model. I could never find out if e-machines took care of the problem. If anyone know about it please post it. I have spent too much money on this laptop, I don't want to just give up and toss it.
    Scholar:
  • 53 Answers
It sounds like an overheating problem there is a sensor that detect heat to stop from damaging the computer check to see if the fan is running and that its not clogged with dust.also you can try a laptop cooling pad this may help. but make sure the fan in the computer is running and uo to speed you may need a new cooling fan.if it keeps shutting down you may need to have the processor temp checked.with a infared heat sensening gun.
Posted on Feb 20, 2009
Emachines is offering to repair all M68xx series that have exerienced overheating-related issues for free. If the problem can't be resolved within several months, they give you money between $100-$300...They take care of the shipping charges, if shipping is required. See the link for details.
http://www.emachines.com/support/forms/6800.html
I only found out about it this morning. The deadline is within a couple of days (November 11th, at the earliest).
Good luck, all!!
Posted on Nov 08, 2009
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 23, 2012 | Acer Aspire 7720 Notebook
Partition of acer laptop is not balance, so i format it to make it equal. Unfortunately, along the way of formatting . . . it auto shut down by itself. til then the formatting was unsuccessful coz IT...
One of the bad things that happen with lap tops I have observed owning them is they do get hotter than usual, they make a lap USB fan for them which since I have recommended to all of my clients there seems to not be as many issues with heating anymore. Lap tops are designed with protective measures in the BIOS when built to shut down then they get to hot.
A good feature so the cooler your lap top runs the less it will shut down. Also go into the power options settings when you reload and set this to the factory settings and only change the power side that is when it is plugged in only leave the battery settings where they are. I hope this assisted you. Fix this before it becomes a serious issue. Thanks for using FixYa for all your questions. John
Feb 09, 2011 | Computers & Internet
Is it free: My monitor goes to sleep. How do I stop this?
Right click on power options and remove the sleep option.
Hope that helps.
Jan 22, 2011 | HP Computers & Internet
All my saved pictures have been deleted and the screen continually goes blank
Greetings and thanks for the question, there are various reasons why this happens. Without having your computer here to see what is going on is anybody s guess on how to repair it. If I may offer some suggestions. Since I also do not know what operating system you are using I will assume it is Win 7.
I would personally go to control panel and check my power options to make sure I do not have the settings set you close display or sleep mode or anything set to soon to close your machine down. Often times people have these set to go off there are defaulted usually to save battery usage and your lap top from getting to hot and shutting it down. The thermal switch may be activating sooner than normal. What some folks do is purchase one of those underneath fan coolers to keep their lap tops from getting to hot and constantly shutting down.
This can be the case have this checked out at least set the lap top for more time before closing down or turning the monitor off. Let us hope it is not more serious than appears. Like a lamp in the monitor going out. If it is new the lap top I would not worry about that issue because it is intermittent. Which leads me to believe it is a thermal or a shut down issue. Get the cooler fan for your lap top I recommend anyone that reads this post to also do this as well. Clean your lap top blow them out it is critical to do this to keep dust away and keep it clean.
Now there is recovery software which is free to download Click Here to check this out to retrieve lost files. Also important to get those precious memories separate off your computer and on to separate CD or DVD or storage USB stick so that when this type of thing happens you have not lost your precious memories. I hope this helps you. John
Jan 17, 2011 | Samsung NC10-14GW Notebook
Pantech duo keeps shutting off
Sounds like you need a new battery, it may not be fully charging, although it may say so on device. I had a similar problem with my Lap Top, and Fixed it with a new battery.
Jan 22, 2018 | Pantech Duo Smartphone
My computer monitor keeps shutting off randomly for no reason. It isn't the sleep function, I've already checked that and it happens when you are in the middle of using the system. I am running XP
The monitor shuts off or the video card shuts off?
If it's the video card it's probably a heat or driver issue.
If it's the monitor it's probably a heat or ROM issue.
Mar 18, 2010 | Computers & Internet
My medion laptop keeps overheating
change your laptop heat sink fan
Nov 11, 2009 | Computers & Internet
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
My Gateway shuts off, I don't think it has to do with the power
You are infected with a virus or something. Try re-installing the OS and see if this eliminates the problem. If it doesn't help then you have something physically defective.
Sep 20, 2009 | Acer Ferrari 3200 Notebook
E-Machines M6811 Notebook Logo
258 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
