Question about E-Machines Computers & Internet
My W3052 e-machine shuts off with a two tone alarm...dee-doooo-deee---doooo-deee----dooo coming from the tower. Only unplugging the main power cord will stop the alarm. Then I can reboot.. From on line research I'm thinking the Power supply needs replaced. What kind do I need, can I order it on line and would it be difficult for me to replace?
  • 75 Answers
It sounds like it could be your power supplie but with your description still hard to be sure.
the power supplie is fairly easy to replace.most come with directions.
start by unplugging all your power connectors inside the tower.then remove the four screws in the back your done.replace in reverse order.
your machine if it has a stock video card will not need more than a 500 watt power supplie,if you have upgraded the videocard you will need to check with the manufacterer of the card.
if your not sure whats wrong,you could always buy one from bestbuy.if thats not your problem, they will take it back no question asked.
Posted on Mar 03, 2009
  • Charles Stillwell
    Charles Stillwell Mar 03, 2009
    I just wanted to add that i just bought a very exspensive power supplie from ebay.it was brand new.its bad!!!!
    Thermaltake wont honor the warranty because i bought it from ebay.be careful where you purchase and what you purchase.
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
I changed the fsb from 166mhz to 200mhz on my computer
SHOW YOUR MOTHERBOARD TO ANY GOOD COMPUTER HARDWARE THEY WILL HELP YOU
Oct 21, 2009 | E-Machines W3052 PC Desktop
Emachines W3052 Gets stuck on logo screen when starting up.
My computer does a similar thing, the issue with mine is the mother board which requires everything to be at a certain temperature. Let it run on the start screen for a couple minutes and hit the reset button. If it doesn't boot up you're going to have to get more involved with your PC. Turn off the power, unplug the cord from your power supply, open the case, look for the battery and the JP8 (CLRTC) jumper. Move the jumper from pins 1-2 over to 2-3, wait 30 seconds, and move the jumper back. Close the case, plug in the power cord, turn on your machine, and boot it up. If it still fails to boot check that all cables are securely attached (inside and out), check that the RAM is securely seated, and check the CMOS battery to be sure it is not dead. Beyond this you're looking at a component failure and should contact a repair tech.
P.S. if you feel up to it and can't wait for service, pull the hard drive out of the first computer and use it in a different computer. Be sure to unplug the hard drive from the second computer.
May 16, 2009 | E-Machines W3052 PC Desktop
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Tower not coming on
Check the power supply, if you don't hear any whir at all from the fan, power supply needs to be replaced.
Jan 04, 2009 | Computers & Internet
W3052 E-Machine shuts down
Take the RAM out of its slot then put it again, also if you have an PCI device on your motherboard check whether they are inserted properly or not, try this one
Nov 16, 2008 | E-Machines eMachines Desktop PC
Steady tone coming from ghw9150pw0
could be problem in control bd not necessarily a problem with function but something in sound circuit ck for a sound control button on keypad it may say something like alarm volume or on off try holding it down after turning power on if you notice any change in volume or tone of sound shows you're on right track only thing is solution may mean new control bd
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Computers & Internet Logo
168 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
