Question about Philips 47PFL3603D LCD TV
Watching tv sound goes static
Sound goes static when watching tv you change the channel and its fine for a while then it goes to static again change channel and its fine connections are all good it does it on every input i have connected to the tv
  • Anonymous Feb 24, 2009
    TV Audio becomes loud static, picture is fine. Happens periodically, changing channel or turning off then one fixes for a time. Input is HDMI from PS3.
  • Anonymous Mar 29, 2014
    Occasionally I get a static sound and can change the channel and change back and it resolves. Aggravating!!
  • 6,784 Answers
Hi there, this is a tuner issue. it can be repaired or replaced.
Posted on Feb 20, 2009
Projection TV. DVD works. Cable often seems, "untuned". Static & un-fine-tuned sound of channel with black screen. Then, later, it will come on just fine. Sometimes, will go back to untuned status.
I would suspect your cable box first. I would unplug the power cable from your cable box and wait 60 seconds. Plug it back in and try to watch cable tv. I would also make sure the coaxial cable going from the wall to your cable box is connected properly. I would also make sure the cable going from the cable box to the tv is connected properly. Test your tv and see if it works correctly when you watch cable. If this fixes the issue you are good to go.
  • If this makes no difference use a set of new cables if you have them.
  • If this does not work then call your cable company. They may have to replace your cable box.
May 25, 2015 | Televison & Video
Issue with Samsung LE32B450. After the TV has been on for about 5 minutes, when you change channel the screen goes blank and the sound goes off. However, the TV is still on as pressing the power but
Just do a hard reset to this set and check. Unplug the TV from AC mains wall socket, and re-plug it back after 10 minutes or so. This must make it a hard reset.
Jan 12, 2013 | Samsung LE32B450 32 in. LCD TV
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
High audio static on all but one channel of my RCA TV
had this problem for a while only just found the cause, its either your tuner flipped out which means you just neded to retune the tv and it should be fixed if not that there was this setting i found still not sure what it is or means but you could select these letters i think there was S, BG and some other ones but i changed it to the top one which was BG and it fixed the static sound with the clear picture problem just stuff around with the channel settings and see if you have that setting hope that helped
Aug 16, 2009 | RCA Televison & Video
RCA 32'' TV .....Good Picture but No Sound
try changing the channel you outputing to. go to your tv1 location hit the menu button and choose number 6 system setup then number 1 instalation then number 5 modulator setup then change tv2's channel to like 65 then select done go to your tv2 put on 65 and see if this helps issue
Nov 14, 2008 | Televison & Video
Suddenly no sound & no picture overnight: is my TV dead?
If you have static siugnal, sure TV is not dead.
Check the aerial cable, ensure it is well plugged in and getting signal.
If you are using a receiver box, check cables to TV and receiver (freeview, sat, cable etc.), try setting channels on receiver again, if it does not work but you get static, then either the cables or receiver are defective.
Test the TV on standalone , connecting it to an external antenna.
Tune again the channels, and save the preset.
If still no signal then the antenna socket on the TV may be defective.
Try using the TV with a DVD.
If you can watch DVDs, and TV is not keeping channels preset, and you tried all the above, at this point htere may be a fault in the tuner card inside tv.
Call the phone number listed on tv user manual to get support, and eventually repair it.
Oct 03, 2008 | Panasonic CT-36HL43 36" TV
Sound and Volume trouble
I bought my Insignia 32" LCD in November 2007 - same problem. I figured out that if you press the "input" button on your remote select any of the other options "component 1, composite 1, etc.. that you're TV isn't on -then press "input" again and go back to the component that you're TV plays on - you'll have volume when you go back every time. I've gotten so used to doing it now that it's become habit. 9 times out of 10 I have to do it.
Mar 15, 2008 | Insignia IS-LCDTV32 32 in. Television
Audio problem
Is this problem only on one channel? How is the sound on other tv's in the house? You may have a weak signal on this one channel
Lou Margo
loumargo@verizon.net
Nov 18, 2007 | Polaroid FLM-3201 Television
White Noise Sound
Your problem is somewhere between the tuner and video detector circuit. The signal entering your TV carries: video,red color,and blue color as well as sychronizing pulses for color and horizontal and vertical deflection ( actually vertical sync. is derived from horizontal sync.) along with burst pulses to synchronize the color. After all these, the sound is an fm signal entwined with a pilot signal for stereo audio. WHAT a mess! After the audio passes through all this, it is detected and sent to the audio processor. If any frequency has drifted away from it's value then you loose the sound. SO... your problem could be in any of the tuned circuits or in the audio processor IC (chip). Any component changing value could creat this problem. Most likely the audio processor IC. You'd need to have the set checked out by a tech to find your problem. Stargazer
Mar 11, 2007 | Proscan PS32600 32" TV
No Picture, sound is all static
Make sure the ant. input switch didnt change and check the ant. connections If that dosent work sounds like a defective tuner.
Mar 30, 2006 | Philips Magnavox 27MS343S 27" TV
Philips 47PFL3603D LCD TV Logo
590 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
