Question about HP PSC 1210 All-In-One InkJet Printer
Printer ink cartridge not recognized by printer hp psc 1210
Refilled ink manually, error message says that cartridge is not installed properly, even though it is seated in the printer head properly. Tried to clean the cartridge nozzle, but that didn't seem to help.
I also get a error message on the printer itself, and the printer will not power off when I hit the power button
    Sergeant:
  • 199 Answers
Some time hp printer does not reconize refill cartridge or cartridge is damage when refilled so change cartridge
Posted on Feb 27, 2009
Cannot recognized ink in my canon pixma ip2770
i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
Aug 31, 2012 | Canon Office Equipment & Supplies
I keep receiving an error message about the cartridges.
hello, i have found that refilled ink cartridges fail more than hp oem, and that mixing, refilled with hp oem, sometimes the refilled will cause a short, and point to the wrong cartridge as being deffective. though i have had the actuall carriage unit fail electronicly. but the simpliest thing to do would clean the electronics on the cartridge, as well as the contacts on the carraige unit, you will need isopropyl alcohol, and a soft paper towel. if that does not work, then i would recommend replace both ink cartridges with hp oem inks, not refills.
Oct 04, 2010 | HP PSC 1210 All-In-One InkJet Printer
I have a hp psc 1200 . i have not insert the printer cartridge. will the scanner work ?
Inkjet Printer will not operate with out the ink cartridges inserted. The Error message on display will not allow the printer to work.
Regards
Riztech
Jun 16, 2010 | HP PSC 1210 All-In-One InkJet Printer
My printer doesnt print anymore error msg and will not turn off. Ive installed new print cartridges and no luck keep getting the error msg and wont print at all. I have a psc 1210 all in one
What is the error message?
Also, please consider the following:
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
Get refilled ink cart. to work
probably one of your cartridge is no good
check the contacts ..try clean them with
a wet towel
Apr 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Hp psc 2110 incorrect ink cartridge message.
Hi plabonne,
I hopped out to HP's support site for stats on your cartridge and found some info at this link:
http://www.shopping.hp.com/webapp/shopping/supplies_model.do?product_code=C8648A&jumpid=oc_R1002_USENC-002_HP%20PSC%202110%20All-in-One%20Printer&lang=en&cc=us
are you using an HP 57 Tri-color cartridge? HP printers work best with HP cartridges and often have problems with refilled cartridges. the grinding noise you're hearing makes me wonder if the cartridge isn't seated all the way in its little carridge (the plastic part that holds the cartridge). have you had a chance to slip teh cartridge back out and try gently slipping it back in again?
here's another link to try for info for this model of printer (HP's support site), with specifics about your error message about half way down the page:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=bpu05206&dlc=en&product=79488
hope this helps!
-JW50
Nov 04, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp psc 1210 all in one won't print with new cartridges
Most of the time when the error pops up it is due to problems with either the printer reading the cartridge is in from the contacts or the cartridge contacts are damaged.
I should also point out that refilled and remanufactured cartridges are the number one reason for the error but assuming that you are using hp cartridges fresh out of the pack take a look at this link and follow the steps. I would type them out but it even has pictures for easy reference!!
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042818&cc=us&lc=en&dlc=en&product=79499&dlc=en&lang=en
If you are not using hp cartridges then replace with genuine cartridges and it will most likely resolve the issue - the printer is able to tell the difference between a new and refilled/remanufactured and often times will reject the cartridge because of this.
Aug 06, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 1210 all in one printer - error message
Two problems;
1 - This unit cannot be set back to factory settings as it does not have the keypad to enable this functionality.
2.
Jul 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1210 All-In-One InkJet Printer Logo
501 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
