Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
The arm on my 1015 Werlitzer will not reset itself.
The arm on a 1015 Werlitzer will not reset itself after playing a record. I know this is an easy fix. A repair man showed me once. Of course yrs. latter I cant remember.
  • 3 Answers
Sometimes it takes reseting the program. The manual will show you how. If you go over a certain amount of plays, it won't play anymore. Call a reputable dealer and they can help you over the phone, if you don't have a manual.
Posted on Dec 01, 2009
    Champion:
  • Wurlitzer Expert
  • 211 Answers
As the tone arm reaches the centre of the record a brack underneath the centre post moves and clicks a switch. Loosen the mech bolts and lift up the front edge of the mech and you will see it underneath the tone arm.
Posted on Oct 28, 2009
  • 38 Answers
THE GEARS OR OUT OF LUBRICATION.
LUBRICATE WITH WHITE LUBE GREACE.
THEN TURN THE KNOB ON THE GRIPER ARM
TO RAISE, AND LOWER THE ARM. THE ARM IS STUCK.
DOCTOR FIX IT
IN-HOME JUKEBOX REPAIR
6362273300
BALLWIN MO.
Posted on Jun 10, 2009
  • DOCTOR FIX Dec 02, 2009
    THE ANSWER,(REPLYS) ABOVE SEEM TO BE FOR A VENIAL JUKE BOX. THE QUESTION'S HEADING , AS I READ IT , IS FOR A CD BOX.
Wurlitzer jukebox 1015 78rpm records needle does not start at the begining sometimes starts 1/2" in. How do I adjust tone arm
If you study the screws around the cradle that the tone arm sits in you will see that it is adjustable. This determines where the tone arm is when the record comes up. If the machine was always wrong like this it may have been set for 45rpm records. You need to adjust the whole tone arm post with the screw that goes up into the base of the post..
Mar 22, 2013 | Audio Players & Recorders
Wurlitzer 1015 jukebox
It is the arm sensor for the end of the disk.
Apr 05, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Nov 09, 2011 | Crosley 0187SST Turntable
KEEP ON PLAYING THE SAME RECORD
If it is a simplex mechanism then when a selection is made a small 'pin' pops up. The machine then sets going and an arm sweeps round until it bumps into the pin and then goes into the play cycle. The arm is stuck up against the pin because it hasn't reset and so it plays over and over.
Have a look on the right hand side, below the mechanism base board and you will see the circular solenoid selection assembly and the arm that sweeps round. Press the pin back down that is against the sweep arm and it should start working.
Dave F.
Oct 14, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1800 jukebox, plays record but at end the arm does not lift so record does not reject until I press the reset button and then it works.
If the normal cancel button is working then take a look at the tone arm trip switch, which probably just needs adjusting. You can test this by flicking it with your finger when a record is playing. If it works it just needs adjusting to trip at the right place on the record.
The trip switch is located behind the fat end of the cobra tone arm on the back side of the arch, so you get to it by taking the machine back door off.
Dave F.
Nov 29, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
3400 series werlitzer 1970 jukebox
Look in the back. If you 'pop' a pin on the selector ring (press at the bottom of the small springs) so it pops up and the machine then plays o.k. then it is probably a bad contact in your keyboard leaf switches. Run a stiff piece of paper or card between the contacts to clean them.
If it doesn't play, then you have more complicated problems.
Mar 28, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
231 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
