Question about DISH Network DVR 510 DTV Receiver / 100-Hours Video Recorder
510 DVR has to reload sat signal when accessing recorded events.
It's a DISH Network 510 receiver that frequently 'fritzes out' when accessing recorded events. First the entire TV screen will turn a solid color (green, pink, white - usually green) and then the receiver has to reaquire the satellite signal before being able to access the recorded event. This problem only started within the past week. My guess is that it was either a software upgrade or the receiver is dying. Any ideas?
  • 374 Answers
There was not a software upgrade in the last month for the 510 according to Dish Network. With that being said the issue is more than likely a bad hard drive. If you have to replace the receiver ask about a non dvr model that supports an external hard drive. This will allow you to keep from paying the dvr fee every month and allow you to have better control of your recordings eg. more record time, saved recordings if receiver needs to be replaced etc. There is a 39.99 one time fee for Dish to enable this feature but it is well worth it in my opinion. You may also want to check out the line of Sling media they have available also if you are an avid TV fan.
Posted on Feb 23, 2009
My 622 DVR dual (DISH ) receiver has lost 3 local channels in a row ( SAT 61.5) . Connecticut 7385,7386,7387 - (ch 20,24,26.) Other tv's/ HD box and old 310 box converters work fine. I have unplugged,...
Hello, my name is Daniel Busa with Dish Network customer service. Whats probably causing the issue would be that either you're not getting high enough signal strength on the 61.5 satellite. Otherwise there could be an issue with the box if you swap it with another reciever in the home, and the issue follws it you'll need a new box.
Oct 19, 2010 | DISH Network ViP622 DVR DTV Receiver /...
DVR refuses to rewind or pause live TV or record
ruukasu2005,
If you are still experiencing problems with your 625 receiver performing live DVR functions, try unplugging the receiver for about 10 seconds and plugging back in. This will cause the receiver to reboot and acquire satellite signal. After the picture returns, then try to pause. If it still doesn't work, then we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Jul 08, 2010 | DISH Network DVR-625 DTV Receiver /...
DVR 510 DTV Receiver / 100-Hours Video Recorder: I have a dish 510 receiver that's been playing bac...
Guest,
The receiver may be developing a hard drive problem. Have you seen any error messages pop up on the TV screen (024 or 311)? The receiver may need to be replaced. You can call 1-800-333-3474. I hope this helps.
Ray Calo
DISH Network - Executive Offices
May 18, 2010 | DISH Network DVR 510 DTV Receiver /...
I recorded 'Rocky' on the DVR at 4/16/10. Once I saw it on the recorded movie list, I made sure to protect it, and it was fine until today, when it just suddenly disappeared. The event list is currently...
Hi, my name is Phillip Chang and I work with DISH Network's Technical Support Team.
We are sorry to hear that Rocky was not recorded like you had wanted it to be. If this were to ever happen again unplug the receiver for 10 seconds then plug it back in.
If the issue continues after this give us a call at out 24/7 technical support number for additional steps:
1-800-333-DISH (3474)
May 04, 2010 | DISH Network DVR 510 DTV Receiver /...
My dvr will not record. We moved the location of the tv and may not have hooked everything back up correctly. I have 2 tvs on this receiver and it will not record on 1 or 2.
dvr's record from the signal input, not from the tv. tv's are just used to display.i expect the input from ariel? sat dish? freeview box? is not connected right
Jan 25, 2010 | DISH Network DVR-625 DTV Receiver /...
Dish 510 DVR that wont record properly or play paused TV show
Make sure that the software is correct. Should be P4.07
you can go into the DVR and replace the hard drive but I would suggest getting Dish Home Plan, Replace the receiver and then cancel the Home Plan. Talk to Dish Network and they will work with you.
for tech support go to: tech.dishnetwork.com
Dec 27, 2009 | DISH Network DVR 510 DTV Receiver /...
Dish 625 DVR recorder won't play recorded shows. It gives me an error code (05)
Hi I will be more than glad to assist you in this concern. First press the power button on the front panel of the receiver for 10secs. once you press it the receiver will turn off and it should turn on by itself, once it turns on by itself you will see attention 015, press the menu button on the upper left of the remote, once you see the menu button press 6, 1, 1 on the remote and it should show on the screen point dish, select on check switch, once u are on the installation summary screen, select on test and it should do a test of 1 of 3 or it depends on your sat orbital location that u have.. once its done, it will show the installation summary screen and you should see sat input 1 & 2 with port1 up to 2 or 3 depends on your sat orbital location, all the trans on the sat 119, 110 or 129 if you have should be ok and green. once you see that all ok, select done on the screen, and it will be back to point dish, select done again, and then cancel all the way out of the menu, it should show on the screen attention 015, let it finish until it download the programming guide, once its done it should show a tv pic. press the dvr button and access your recorded event, it should play the dvr event. if the problem still exist, unplug the power of the dvr from the power outlet for 1 minunte then plug it back again and it should acquire the sat signal and download the programming guide, once it shows a pic. press again the dvr button and access the recorded event. it should play the recorded event, just incase the problem still exist, check what will be the exact error msg, write it down in a piece of paper and please feel free to get in touch or you can call on 1-800-333-3474..in order to for the dish tech support replace the receiver, this is a dvr lost of function.
Sep 05, 2009 | DISH Network DVR-625 DTV Receiver /...
Receiver 510 error code 836
err 836 means you have changed your recvr to a different dish or LNB's or your missing one or more satellites needed for your installation or programming needs. if this has been in the same location and connected tot he same dish and you dont have sats 105,or 121 listed in the install summary then you will need a technician to check your dish. It could be out of alignment or a faulty LNB.
Jun 21, 2009 | DISH Network DVR 510 DTV Receiver /...
Want to copy shows recorded to DVR onto computer Howto...
ArmyMason,
Unfortunately as a Dish Network Employee I must inform you that acording to Dish that is not possible however a good computer tech may be able to help you with a work around but keep in mind that if any damage occurs to the receiver that Dish will charge you for the receiver. When you do upgrade check into the receiver models that have an expansion port for an external hard drive. A 211 which is a solo hidefinition receiver without DVR can have a port activated for as one time charge of 39.99 and you can use the hard drive you supply as the DVR. Yoiu also will not be accessed the 5.98 DVR fee every month and if the receiver needs replacing you still have your recordings. Thanks for using Fix Ya.
Apr 01, 2009 | DISH Network DVR 510 DTV Receiver /...
I want to copy the programs recorded on my dvr 510.
According to engineering aspects of the 510 it is not designed to allow the recordings to be transferred. The only option you have is the option you mentioned or purchasing the 510 and having it incorporated into the new system so you can access them. I am sorry I did not have any better news for you. Thanks for using Fix Ya and if you need further assistance please let me know.
Jan 14, 2009 | DISH Network DVR 510 DTV Receiver /...
Televison & Video Logo
183 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
