Question about Frigidaire FRS26R4A Side by Side Refrigerator
Door handle removal
Can't figure out how to remove door handle to fix it
    Problem Solver:
  • 8 Answers
Hello...what is your model number? If you're talking about the FRS26R4A, the top plastic piece on the top part of the handle slides up and off. The bottom plastic piece on the bottom part of the handle slides down and off. Hope this helps.
Posted on Feb 20, 2009
  • 548 Answers
On the door handle there should be some small plastic parts that will slip off. You may need a small screwdriver to pry them up. Be careful since you have to live with any marks you leave on them. These plastic pieces should be at the top and bottom of the handle. Pry them up and the screws should be underneath them.
In the chance that you can see a small screw with a funny head on it, you may need either a torx head or allen wrench to turn it.
2 Suggested Answers
SOURCE: Need to remove door handles in order to get it through the door.
You have to remove the screws under the magnetic door seal . The inner side of the door seal will
lift up enough so that you can get to the screws.the screws hold the door seal and the inner plastic liner in place.When you have removed enough screws, you will be able to pull the liner out so you can get to the screws holding the door handle on.
Posted on May 09, 2009
The exterior door handle on my 1993 Nissan pickup broke. I have a new handle but can't figure out how to remove the inside door panel to get to the area where I can remove the old handle and replace with...
Inside door handle should have some screws that need to be removed and the window crank will have a c-clip behind it . or some you have to pop the cover off the window crank
Oct 14, 2017 | 1993 Nissan Pickup
I have a 1997 F-250 HD. Driver door latch cable is broken at the handle end. I have a replacement cable, but need help figuring out how to remove the broken cable without breaking the plastic rod...
Door Handle/Latch Assembly NOTE: Due to the conversion from single 90-degree rod end shape to double 90-degree rod end shape, it may be necessary to remove more parts than the instructions indicate. This action will allow more maneuverability of the rod and ease the removal process.
Handle, Outside Door, Front Removal
  1. Remove the front door trim panel (23942) and front door trim shield (237A04) from the front door (20124). Refer to Section 01-05 .
  1. Disconnect the front door latch actuating rod (22152) from the handle link connector.
  1. Remove one nut and screw.
  1. Remove handle and pads from door.
Some rods are double 90 degree rods, they require the handle or lach to be free when the rod is attached.
Some have plastic clips that slide onto the rod. they pop off sideways.
May 06, 2011 | Ford F-250 Cars & Trucks
I did a really dumb thing... Kohler bypass shower doors, frameless. For some odd reason, the bottom piece fell off the inside door! I scraped off the left over silicon glue, got some more, and very...
I know it's is going to be a tedious process to remove,clean, and replace bottom piece but I think that is what you need to do. Sorry I don't have a easy fix for you. Good luck and thank you.
Jan 25, 2011 | Kohler Home
Need to figure out steps for taking off door so i can fix my handle.
ther are screws but to the door panel. first u must remove them. gently pray towards you and rise. unplugged any connectors. pull away any plastic behind door panel to acsess the handle
Sep 21, 2010 | 1998 Toyota Tacoma
I got a 1999 ferrari 360 modena and im trying to figure out how to fix the door handle... can u guys help me out??
Hi I had a similar problem on the passenger door, when I lifted the handle the door would not open from the inside. The problem I had was that the wire running from the handle to the lock had become unclipped. This was a very easy fix....if you remove the hand rest panel behind the inner door handle( it just unclips) then you can see the pull wire, with my problem a plastic bracket had unclipped from the handle it only needs to be reattached to the handle and the problem is fixed.
Oct 11, 2009 | 2004 Ferrari 360 Modena
I can't figure out how to remove the OEM door lock cylinder in my 1994 K1500 Blazer. I can get the handle unfastened, but not removed from the door. Also, can't figure out how to remove the retaining clips...
in order to remove the cylinder, You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.then you have to pull back the seal covering the door and remove the bolts holding the handle, door cylinder, and linkage assembly from inside the door
Aug 18, 2009 | 1994 Chevrolet S-10 Blazer
Cant figure out how to remove the door panel to fix my door
After you have made sure that all the screws are out there are little christmas tree looking clips that hold the door paned on. Just pull out on the panel, then push up on the panel and release the top.
Jul 22, 2009 | 1990 Buick LeSabre
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
1998 Toyota Camry Inside Door Handle
The Door Panel Has Got To Be Removed.
Start By Removing The Handle Cover You Mentioned On The Handle Careful Not To Break It . A Small Screwdriver Can Help.
Next Remove Black Piece By The Window By Pulling It Strait Outward. Then Remove The Screw Cover On The Actual Handle You Use To Close The Door. Remove The Screw From Below It And There Is One Under The Front Edge Of It As Well. There is 2 screw along the bottom edge of the door as well. then remove screw up by the mirror. now remove this little plastic clip right on the side closest to the outer edge by pressing the center and pulling the whole thing out. Then There Are 2 10mm screw that hold on the door latch remove and slide the whole handle forward and it should come free. Now Reverse all these steps with the new handle in place.
THIS SEEMS HARDER THEN IT IS I PROMISE.
If You Have Any Questions What So Ever Please Feel Free To Post Then And I Hope I Helped At least A Little.
Nov 10, 2008 | 1998 Toyota Camry
Ford focus door handle
If it's an exterior door handle that you need to replace on your 00-07 Ford Focus, this video will show you how to fix it.
Jun 12, 2008 | 2004 Ford Focus
Frigidaire FRS26R4A Side by Side Refrigerator Logo
125 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
