Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Washing indicators light is flashing and dishwasher won`t start
We moved into a new house and the dishwasher was built in - no manual or instructions and we can`t get the dishwasher to start.
Any suggestions?
  • 686 Answers
Try to start again while applying closing pressure {push in} at the top of door where latch mechanism is if it starts then it's an adjustment that needs to be done on the door latch
Posted on Feb 20, 2009
My kenmore elite dishwasher is brand new but tonight it is flashing locked and I can't get it to do anything
Some times just turning off the power for a few minutes will reset the program--if not, in your instructions you should find what the flashing light is an indicator of--
Jul 14, 2014 | Kenmore 24 in. 17482 / 17484 / 17489...
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Apr 08, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
Blinking lights on frigidaire dishwasher
Hello - Try resetting the dishwasher by disconnecting the power to the unit. This will clear most flashing lights. You can disconnect power by flipping the circuit house breaker off and back on for approximately two minutes. If this does not prove to be successful, contact a professional to move forward accurately. Dishwasher could possibly have a faulty control board or wiring failure.
Oct 10, 2012 | Frigidaire 24 in. PLD2850 Built-in...
Trying to start the unit but the washing light indicator only flashes.
this means the machine has started the cycle...that is the washing light is flashing. However if nothing happens then the drain pump is not working firstly. Machines usually drain first any bit of left over water then go yo fill up. As you havent ststed the make and model i assume the drain pump is faulty. or the water inlet is not working. More precise info is needed to advise you further
Aug 01, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Model No LD-14AWZ Wash rinse and dry lights flashing. IE flashes on display board.Model no LD-14AWZ
not sure if im on the rite page we have move into a house that has a disherwasher LG Model LD/14AW2 there was no instruction book left at the house cant seem to get it to work even though it looks quite a new dishwasher do anyone know where i could get a instruction book from thanks noelene
Jun 26, 2010 | LG 24 in. LD-12BW5 Free-standing...
The clean light is flashing. The unit will not start.
This is an indication that the water did not heat properly. I have created some instructions on how to reset the control so you can use the dishwasher and some ideas on why the failure occurred. Follow the link below and let me know if it was helpful.
Clean light flashing
Jun 20, 2010 | KitchenAid 24 in. KUDS01ILWH Built-in...
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Flashig lights, ticking sound, unfinished cycle
It sounds like it may be a heater problem or motor start problem. If you will post the complete model number from the decal, I may be able to look up something on it.
You should be able to get warranty service even without the proof of purchase as long as the manufacturing date proves it is within the warranty period. The date code is in the serial number.
If you will post it also I can look it up and tell you when it was built.
Thanks/Mike
Nov 09, 2007 | Frigidaire 24 in. FDB1250RE Built-in...
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
294 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
