Question about Festina Chronograph #F67195 Watch for Men
I had to change the battery in my festina 8812, but its not keeping correct time, the secondhand does move but 1 of the chronograph does to. the hour and the minute hand do not move at all? pls help
SOURCE: Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Posted on Aug 11, 2008
SOURCE: reset chronograph minute and hour hands to zero
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
Posted on Aug 27, 2009
  • 2501 Answers
SOURCE: chronograph hands reset to wrong places
go to the citizen web site (citizen.com) and select "technical support" and then "setting instructions".
Enter the number off the back of your watch snd the click on "get setting instructions"
The instructions include the steps you need to take to zero the hands.
Posted on Feb 01, 2010
escapement
  • 2334 Answers
SOURCE: Bulova 96R31 keeps time + date, but the chronograph does not work
The problem is in chronograph module or related gear train. To find what exactly the problem is, special tools and equipment is needed as well as watchmakers knowledge and skill. There may be just an underpowered battery, but according to your explanation, I tend to think that the first causes mentioned by me are the right ones. Visit your nearest watch repair shop and ask to check your watch for any faults. Rate me, please.
Posted on Feb 25, 2010
Testimonial: "I'm the one who submitted the question. Thank you, I will visit a watch repair shop. It's a shame the watch is only 2-3 months old! Thanks again "
  • 101 Answers
SOURCE: Citizen watch secondhand not moving
its a solar watch meaning you have to completely charge the watch under artificial light for 24 hours or full sun for 6 hours
Posted on Aug 19, 2010
Why is my second hand not moving
THE watch is in stop watch mode (pause) , reset your side mounted post buttons to go to normal time
Sep 16, 2015 | Festina F16190/1 Chronograph Watch for Men
How to reset Festina back to zero
Pull out the crown, push the chronograph start button. You will see that the hand moves one second. once it is back to zero push back the crown. Depending on your model you might need to pull out the crown with one click for the chronograph timers and another click for the second hand.
Jul 01, 2014 | Festina Watches
I need a manual for a Festina, Chrono Bike, watch
Festina do not have much of a web site at present but if you go to "www.festinausa.com/", you will see a customer service address who may be able to help you.
Mar 12, 2010 | Festina Chronograph 16162/1 watch
How do I set the time and date?
Twist the crown until you can pull it back one notch. This will set the alarm by twisting in one direction. If you twist it in the other direction, you will set the date. Pull back one more notch and this will set the time. One you've done this, push and tighten the crown back in and press the bottom right hand button. The second hand should begin moving.
Dec 20, 2009 | Festina Chronograph 16162/1 watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
Festina chrono bike 16162
Pull the crown out to the first click, then you can turn one direction to set the alarm, and the other direction to set the date.
Jan 20, 2009 | Festina Chronograph 16162/1 watch
My longines watch changes date at midday. Help
You have the watch set so that midnight is showing as noon. Advance the watch 12 hours and then reset the date to the proper setting.
Jan 12, 2009 | Festina Chronograph 16162/1 watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Festina Chronograph #F67195 Watch for Men Logo
813 people viewed this question
Top Festina Watches Experts
Ansel Alberto
Ansel Alberto
240cpa
Are you a Festina Watch Expert? Answer questions, earn points and help others
