Question about Epson Stylus C46 InkJet Printer
Does not print
The red lamp blinks. It says on the screen that parts may have outlived their useful lives.
  • 353 Answers
I presume both the red and green lights are blinking.
It means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation.However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is useful for this, copies are available from a number of sellers - just Google "Epson C46 Service Manual". You will often find them for sale very cheaply on E-Bay. However, a service manual is not essential.
If you decide to have a go at replacing the ink pads yourself, or if you have further queries, post a new comment and I will provide further help.
If this solution is useful to you, please rate it.
Posted on Feb 22, 2009
The "lamp" light keeps blinking red. Does this
The lamp life becomes 0%, when used
for approximately 4,000 hours with "Eco
Mode" or when used for approximately
2,000 hours with "Standard Mode" (see
page 43).
When the remaining lamp life becomes
5% or less, " " (yellow) will be displayed
on the screen. When the percentage becomes
0%, " " will change to " " (red),
the lamp will automatically turn off and
then the projector will automatically enter
the standby mode. At this time, the
lamp indicator will illuminate in red.
If you try to turn on the projector a fourth
time without replacing the lamp, the projector
will not turn on.
If you require the manual to help with changing the bulb, send me an email to LBrown18062@hotmail.com Put SHARP PG-B10S in the subject line. I will send it to you right away. Lawrence Brown
Oct 26, 2011 | Sharp Notevision PG-B10S Multimedia...
Lamp light turns on
How is the picture is it dimmer than usual? Also how many times does the lamp light blink in between each pause? A faulty lamp/live driver on this one would cause it to blink 5 times.. Try counting it and let me know.
Jul 16, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
The green light blink for a while and then shuts off and the lamp light blinks once red???
The green blinking lamp means that the TV is getting ready to start the lamp, and then one red LAMP blink means the lamp will not start. You may need a new lamp (Part TYLA1001.)
If a tech confirms this, and you can source the part, you can find TYLA1001 installation instructions here to save a few dollars, and PT-52LCX66 lamp timer reset steps here.
I hope that helps.
Mar 20, 2010 | Panasonic PT-52LCX66 Projection Television
Hello, We have the Panasonic project TV (PT-50LC14). We purchased a new bulb this past July. We're now experiencing problems with the TV. After turning it on for less than 5 minutes, the TV shuts off. ...
Hello well this kind of problem all the time is because you have a fan problem and you could have dirt inside of your tv and sounds also like a ballast problem i have this issue also and I got connected on the live chat that a web say has that they call discount-merchant they sell parts and lamps for TV they could help you they help me twice.
Regards
Jan 01, 2010 | Panasonic PT-50LC14 50" Rear Projection...
KDSR50XBR1 won't stay on
Thanks for update.
Replace TV lamp and every thing will be OK.
Avoid aftermarket lamps and buy original Sony Lamp under following part number from Sony Accessories Store.
F93087600 XL-5100 LAMP BLOCK
Feb 05, 2009 | Sony KDS-R50XBR1 50" HDTV
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
No picture
replace the lamp and the lamp ballast board using ONLY Sony Parts.lamp A-1606-034B ballast 1-468-798-16 this worked for mine.
Oct 02, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Epson Stylus C46 InkJet Printer Logo
74 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
