Question about Sanyo STW0923H2 Air Conditioner Heat Pump
Making noise, not cooling, does not turn on
I have 6 ptac with different problems, like one not cooling, one does not turn on, and one makes lot of noise
If you can help me with this 3 problems,
It will be highly appreciated
thanks
geet kapoor
  • Dennis Boxerman May 11, 2010
    problems too vague. Give more info and maybe we can get them going.
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Projector makes lots of noise
Yes, that can solve the problem because there's also a possibility that the lamp is the one that is causing the noise..
Hope that helps........
Aug 18, 2008 | InFocus ScreenPlay 5700 Multimedia...
My old GE PTAC unit doesn't cool sufficiently & sometimes makes load clunk or thump noise when it cycles off. Is there anything I can try to do?
if it is YOUR unit then do whatever you want . if it is your landlords then this should be his problem not yours
Sep 05, 2015 | GE Heating & Cooling
GE PTAC 5500 series cooling and then blowing hot
Cooling gas is missing. Call some AC service in near to fill it, ask more of them for price. Do not switch it on until you solve this to prevent higher damage.
Aug 28, 2014 | Heating & Cooling
Why is my PTAC unit so noisy in the winter months?
hi Jennifer.
this is all i could find.go to this link and see if it helps you to find out why.
Why is my PTAC unit so noisy in the winter months Google Search
Nov 18, 2017 | Heating & Cooling
After unit is on several minutes, sound turns to static, crackling noise. Any ideas
I had this same problem, check the power transistors attached to the heat sink near the large caps, they tend to get cold solder joints after lots of heating and cooling. 15 minutes and good soldering iron will probably make a huge difference. I added extra cooling fins to mine to help dissipate the heat. hopefully wont go bad real soon again. Also check the large caps while your in there, maybe a good time.
Dec 02, 2009 | RCA RT2500 System
I have two ptac units, both want to run 5 or 6 mins. and cut off
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Oct 26, 2009 | GE Zoneline Deluxe Series Cooling &...
Amana ptac- blows same temperature air whether its set at 80 or 65...any ideas?
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Jul 23, 2009 | Amana PTH123B25AM Air Conditioner
Sanyo STW0923H2 Air Conditioner Heat Pump Logo
70 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
