Question about Sharp R-1874 Convection/Microwave Oven
Sharp 1874- Door seems to "jar open" and oven stops
Sharp Convection/microwave R1874F in our motor home will sometimes stop working. It appears that either the top or bottom of the door will "jar itself open" during convection cooking or low bake. If the door is pushed lightly the oven can be started again by pushing the start button. This does not happen every time something is cooked but we have only been using the oven for 1 week. The motor home was new when we puchased it a couple of weeks ago.
  • polly495 Feb 20, 2009
    Thank you! I am going to try calling Sharp's tech. support tomorrow.
  • 686 Answers
If you have a warranty get a new one installed they have to honor your warranty or better yet if they want payment you want new unit sometimes they come deffective from the factory ad you may have gotten one of them
Posted on Feb 20, 2009
Sharp R-1874 works only by pressing the door in
Your connection is bad. Start with a good and complete cleaning of the product. UNPLUG FIRST. Sometimes in the hinges things gum it up. DO NOT STICK anything into the door latch area.
If this continues, you have an issue that must be decided if you should REPLACE or repair. Repair will cost more than replacing. Sorry.
Mar 06, 2014 | Sharp R-1874 Convection/Microwave Oven
My r-1874 microwave unit will not run unless a small wood handle is put under the door. This has worked in the past but now this little trick does not work. Any idea the part that not working properly
I would say the mount for your bottom or top door switch is loose, misaligned, or broken. And you may have a failed door as well. See my help file on door switches here.
Slamming the door and opening the door while it's cooking instead of hitting the "Stop" pad before opening it both contribute to door switch trouble.
The service manuals covering this model are here and here.
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Feb 16, 2014 | Sharp R-1874 Convection/Microwave Oven
Sharp microwave & convection & turn table on model R1874F won't work
That would be just a defective secondary interlock (bottom door switch) or its mount.
My help file on door switches is here.
The service manuals you need are here and here.
You can get other Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Jan 07, 2013 | Microwave Ovens
Sharp Carousel Model R-1874 no heating or turning, display works
sorry without seeing the machine we can not help try whatever you want . that is how many of us learned what we know today
Nov 17, 2017 | Sharp R-1874 Convection/Microwave Oven
I have a sharp model 1874 when you punch in the mintues it will only go to 59 seconds and shuts off. if i hit 10 mintues it will stop at 9:01
change damper motor and switch. cost is approx $30.00. unit must have cover removed to gain access to motor & switch
Bob
Dec 15, 2009 | Sharp R-1874 Convection/Microwave Oven
R-1874 shuts down after 59 seconds
That switch is supposed to tell the computer if the damper door is open or closed. If it does not go to zero ohms, the CPU doesn't know what to do. Check the thermistor too...... just in case...
Sep 12, 2009 | Sharp R-1874 Convection/Microwave Oven
Microwave Key Pad stopped working
buy a new one they are not expensive wal-mart has 1000w for about 80 bucks
Jan 25, 2009 | Sharp R-1874 Convection/Microwave Oven
How do I remove the door from our Sharp R-1874 microwave
Fixed the problem without any help from anyone. If you ask and ask and get no help I guess it is time to take on the problem and see if you can resolve it and I did. NO IT WAS NOT EASY but with a little thought and time over the last 2 days I did get the door changed. Thanks for letting me post even though I got NO help.
Dec 09, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp r-1874 - 59 sec
We have the service manual, and have uploaded it to our site here. It is only a supplemental type, so it does not show disassembly, but it has helpful info and part numbers
We have a handy disassembly video at http://www.microwavedisplay.com
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 22, 2008 | Sharp R-1874 Convection/Microwave Oven
Sharp R-1874 Convection/Microwave Oven Logo
196 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
