Question about Roper RAS6233KQ Top Load Washer
I have a whirlpool washing machine, it will not spin out. Anytime I try to set it to spin cycle when I push the knob in it makes a humming sound but does not spin.....HELP!!!!!!!
This isnt a fix-all solution, but i have the roper top load washer and it has done the same thing i am trying to find the problem, but to get it to spin again we have to move the entire wash bin around and have to turn it (like your screwing it back on) this has happened to me and this is what i have done just to get it to work again, as i said, i am trying to find a repair manual to fix the problem so i can avoid the repair shop.
Posted on Feb 23, 2009
Washing machine gets stuck in the rinse cycle
try cleaning the valve filter on the cold inlet
Apr 21, 2012 | Washing Machines
WASHING MACHINE stopped in mid-cycle
if it stops at the drain and spin cycle check the lid switch,open the lid,set the washer to spin cycle and pull out the timer knob,stick a screw driver into the hole where the strike from the lid goes into and push down,if you don't hear a clicking sound when you push down on the switch in the hole then you have a bad lid switch but if your machine does run sometime it sounds like the switch will work if you push down on it,could be cracked where the screws go into it.
http://www.youtube.com/watch?v=V5aW9WkTFhE watch video on how to replace it.if you do hear a clicking sound when you open and close the lid or push down with the screw driver you could have a bad timer but check the lid switch first
Mar 17, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Spins on one cycle, but not the other
sounds like timer is loosing contacts and time to replace.
Jul 21, 2010 | Whirlpool LSR7333 Top Load Washer
The washing machine goes through the whole cycle but the machine will not do the spin cycle and I think the agitator has a hard time moving?
If you find this check whether the machine pump out the water from the unit listen for the humming sound from the motor if you found the humming sound means your spinning coil is defective kindly replace the motor
Jan 20, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer will not spin
sounds like the timer is shot.
Apr 30, 2009 | Whirlpool Washing Machines
Whirlpool Waher not working
does it make a humming noise if so there might be something in your pump
Dec 19, 2008 | Whirlpool Washing Machines
Wash goes silent at the rinse and spin cycle
if the wash water isn't draining you have a bad lid switch back out the two screws at the bottom of the control panel in the back pull the control panel forward tilt it back on its hinges on the body of the washer you will see a connector with three wires grey green purple make sure the knob is in disconnect the connector and put a jumper wire from gray to purple where it goes to the control panel pull out the knob and see what happens
Mar 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper RAS6233KQ Top Load Washer Logo
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
