Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
99 chevy 3500 diesel
My truck has new plugs and wiers and crank shaft senser and it still dies when you back up and when you just barley have you foot on the gas it will spit ?
  • Anonymous Mar 18, 2014
    starts fine no oil smoke new plugs code lean bank 1 code for 02 sensor which was replaced runs very rough with black smoke on acceleration when it reaches operating temp. tps replaced.new intake gaskets.
    Problem Solver:
  • 17 Answers
Check fuel filter, Fuel pressure is very critical on diesels. 1 or 2 pound drop will virtually make the motor quit.
Posted on Apr 25, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
2006 chevy 3500 dually 6.0L dies as soon as the starter catches. it acts like its going to start right up but dies suddenly. the dash lights or dome light wont come on nor when switches are activated. ...
if thats a diesel inspec fuel injection pump for issues and also glow plugs--underhood chec for bad wiring--if gas engine then a tuneup cud be in order-new plug wires or coil/ign module--fuel pump may be failin
Nov 21, 2010 | 2006 Chevrolet Silverado 3500
Truck won't crank & run when hot
the TPS senser is bad its on the injecter pump or you have a bad crank shaft sonser
Jan 31, 2010 | 1994 Chevrolet C3500
93 chevy 1500 v6 keeps dying out.
Connect a voltmeter set on ac volts to the pickup coil wires (disconnected from the module) and crank the engine.
2. The pick-up coil output should be more than 0.7v AC. If not, replace the pick up coil and distributor shaft.
3. Visually inspect the condition of the magnet on top of the distributor shaft to be in good condition. If not, replace the distributor
1. Disconnect the set timing connector or ground the Tan/Black bypass wire.
2. The check engine light should come on and code 42 should set.
3. If the engine stops stalling, disconnect the pick up coil connector at the Ignition Control Module (ICM).
4. Check acv output from the pick up coil while cranking the engine at a normal cranking speed.
5. If output is less than 700 mv replace the distributor shaft with a new one.
Oct 13, 2009 | Chevrolet 1500 Cars & Trucks
My 01 8.1L chevy will start then die. And
I would give a serious search for a major vacuum leak. Check around the intake manifold with an aerosol spay of starting fluid or a pentetrating oil. One of these will cause an affect of engine stumble or increase in engine speed. Check also all vacuum lines especially around the tree and all larger lines. Good luck my friend, Dana
Sep 21, 2009 | 2001 Chevrolet Silverado 2500HD
Cut off when I put my foot on the gas. Now it will turn over and will not start
it might be the crank shaft postion senser or the cam shaft postion senser. i was having the same problem but it would stall out to when i was driving. so try that i had both replaced and have not had a problem since.
May 01, 2009 | 2000 Dodge Intrepid
02 Cummins 5.9L intermittant shut down
i had a 99 dodge cummins do about the same thing and mine was the crank position senser located behind the starter,but find out if the code matches that as senser is not cheep.hope this will help you.
Mar 17, 2009 | 2002 Dodge Ram 3500 Truck
Engine dies
I had the same problem with my 94 chevy 6.5 diesel,and spent alot of money trying things that people told me to try.I wound up taking it to the dealer and they told me it was the injection pump.They put one in it and that fixed it.It has run great for over a year and a half.This set me back about $4000.00!
May 29, 2008 | 1993 Chevrolet C/K 3500
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
190 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
