Question about Kenmore 26652
Washing machine 26652 kenmore
Wont spin just changed transmission
    Sergeant:
  • 399 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 13, 2009
Washer wont spin
If your waher drains but won't go into the spin cycle, then it is most likely the transmission. BUT make sure that you check it in all the different wash modes, since if it works in one of them then it would change the diagnosis.
Jul 30, 2011 | Kenmore Washing Machines
I have a kenmore model 20422991 washing machine it wont agitate spin or drain but i can here the motor running
Thanks for choosing FixYa and welcome. Your drive motor controls the spinning, agitation, and draining. Even though it is running, the transmission may be bad. Replace the motor drive if this is the case.
Apr 02, 2011 | Kenmore 22422 Top Load Washer
My washer wont spin
Most likely it's a motor coupling. (Between motor and transmission - brakes when you overload it.)
Kenmore washer repair in orange county, ca
appliance repair orange county, ca
Feb 07, 2010 | Washing Machines
Kenmore 80 series washing machine fills but wont agitate draqins but wont agitste or spin
My bet is on the drive coupler. if you can here the motor run and the machine will drain water then 99.9% it will be the drive coupler.
This coupler is behind the motor and is what conects the motor with the transmission.
Jan 11, 2010 | Kenmore 24032\24036 Top Load Washer
door switch need to be replace or bypass :) dont slam the door next time ..
Feb 20, 2009 | Kenmore 26652
Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Kenmore 80 series washer wont spin
do you hear a clicking noise when you close the lid if not check the lid switch if so then check the coupler it is the plastic and rubber piece in between the motor and the transmission
Dec 29, 2008 | Kenmore 22422 Top Load Washer
Washing machine broken, kenmore model 110.92274100
REPLACE THE DIRECT DRIVE COUPLING IT IS BETWEEN THE TRANSMISSION AND THE MOTOR PART NUMBER IS 285753A THE TRANSMISSION IS NOT BAD
Apr 22, 2008 | Washing Machines
Loud clicking noise - wont agitate or spin
I had the same clicking noise. Turned out to be the coupling between the motor and transmission. A $15 plus 1 hour labor fix
Nov 10, 2007 | Kenmore 22422 Top Load Washer
Kenmore 26652 Logo
77 people viewed this question
Sal De
fordexpert
Robert Rankin
