Question about GE JES1142SF Microwave Oven
GE JES1851SB WILL NOT TURN ON
Our microwave will not turn on. It is like it is unplugged. What do we check 1st? Are there any repair guides available.
How on Earth do you get the cover off? Can you buy a tool that woks on those 6 pointed star screws with the little post in the center? And where can you buy the fuses
Posted on Sep 05, 2009
  • 52 Answers
First take off the cover and look for internal fuses, this is the most likely cause and most common.check every fuse inside until you find the blown one.if this does not work I will take you further
Posted on Feb 21, 2009
How do you turn off the turntable in a GE profile microwave
Some models have this option available (we would need to know your model number) but otherwise the only way would be to take apart the microwave and unplug the turntable motor, which I only recommend is done by a licensed technician. Give GE a call for more info at 1-877-959-8688.
Oct 08, 2013 | Microwave Ovens
Where can I get another GE Sensor Microwave oven #JE 186oWH 04
The likely problem with the turntable is a bad turntable motor. If your microwave is JE1860WH, the motor is part 6549W1S017A, and is available here: http://www.appliancefactoryparts.com/search/part/312564/126487 . Other parts for the microwave is http://www.appliancefactoryparts.com/microwaves/ge/je1860wh.html .
Unfortunately, I do not know of any source for this model.
I hope the parts source will help with your current microwave problem.
Dec 31, 2012 | GE Microwave Ovens
Ge microwave turned on by itself and wont turn off
some kind of issue with the microprocessor for the unit that controls this function and others, not likely to be a do it yourself repair.
Dec 23, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
GE model number jvm1790sk 01 over range microwave convection oven turns on when door is closed but i think it is the convection oven that is on cause the turn table does not turn and the light does not...
That's probably a shorted relay on the control circuit board.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sep 16, 2011 | GE JVM1790 1000 Watts Convection /...
Our spacemaker GE microwave somtimes will not shut off. the only way to get that to happen is to unplug it . It does not happen allthe time and seems most frequet when we open the door to check something...
Turn off the breaker in your electric box and then turn it back on, to see if the controls reset. see if that helps. Otherwise you may have to leave the door open until you can have a repair person check out your microwave.
Check out the manufacturers web site, and see if you unit has a recall.
Good luck.
Dec 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave OTR model HVM1750SM1SS turns itself on
There is a Web site dedicated to this issue. I am aware of a suit involving other older models.
You have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
That rule is even more important in this case.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
Next, disconnect the strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11056 and you can get it here for $130.51 plus shipping. (That compares to $189.75 direct form GE)
You can also find helpful exploded view diagrams at that link.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 31, 2010 | GE HVM1750SMSS Microwave Oven
Microwave will suddenly turn on, then give "F3" reading
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
May 05, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
GE JES1456WFC001 microwave oven turns on by itself
You are correct. The keypad is failing.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
If you would like to have us do this for you, we do that for $39.95 plus part costs, assuming we can get the part for this Canadian model.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
Jun 23, 2008 | GE JES1456 Microwave Oven
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE JES1142SF Microwave Oven Logo
153 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
