Question about Kenmore 26652
Wont spin just changed transmission - Kenmore 26652
  • Kenmore Master
  • 528 Answers
Door switch need to be replace or bypass :) dont slam the door next time ..
Posted on Jan 02, 2010
Washer wont spin
If your waher drains but won't go into the spin cycle, then it is most likely the transmission. BUT make sure that you check it in all the different wash modes, since if it works in one of them then it would change the diagnosis.
Jul 30, 2011 | Kenmore Washing Machines
Whirlpool A5380XTWO will not spin or agitate. Is
check the "wig-wags" that shift the transmission in the washer,they are 2 coils(solenoids) located adjacent the motor on the transmission,if they get no power they wont shift transmission into next cycle of wash mode
Feb 03, 2010 | Washing Machines
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Washing machine makes noise but wont spin or
THERES A THREE PIECE COLLECTOR BETWEEN THE MOTOR & THE TRANSMISSION EASY TO GET TO EASY TO CHANGE
Sep 21, 2009 | Washing Machines
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washing machine wont spin
It broke the drive motor to transmission coupling go to www.repairclinic.com enter model number and look for this part. It's easy to change if you know a mechanically inclined individual.
Dec 23, 2008 | Roper RAS8445KQ Top Load Washer
Washer wont spin
It is probably either the transmission or the motor. If the motor does not spin when the tub is trying to spin, then it is likely the high-speed windings on the motor. If the motor spins, but the tub doesn't, it is probable the transmission.
Sep 06, 2008 | KitchenAid Washing Machines
After having the transmission fluid and filter changed on a Regal GS supercharged, the transmission seems to sometimes slip when starting from a stop. I step on the gas to go and after a half second or so...
Who changed the fliud? Maybe the wrong fluid was added. Also some transmissions have bands that can be adjusted. Just be easy on it. You don't wont to burn it out.
Aug 14, 2008 | Buick Regal Cars & Trucks
Frigidaire GLET1142CS0 washer wont spin
I Changed the TUB belt and now it spins.
Jun 10, 2008 | Washing Machines
Replacing spin belt whirlpool clothes washer
There is no belt. This is a direct drive unit. There is a motor coupler located between the motor and the transmission.
Dec 26, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 26652 Logo
Sal De
fordexpert
 Brian Main
Brian Main
