Question about HP PSC 1510 All-In-One InkJet Printer
Hp psc 1510 paper halfway,"check paper" light flashing, but there is no paper jam. When I push the button, the paper will go through and jam halfway.
  • 5 more comments
  • salem4444 Feb 21, 2009
    I have the same problem, paper goes halfway without printing, than the check paper light flashes, I push that button, the paper goes out, and another sheet go halfway, the check paper light begin flashing again, and it goes like this indefinitely...Please help!!!
  • telos81 Mar 29, 2009
    i have the exact same problem ... i haven't found any solutions anywhere!!
  • Jessy Serrao Apr 06, 2009
    I have the same problem. Check cartridge/check paper light keeps flashing. Changed the cartridge, checked the paper. I press the button, and sometimes it will fix itself and let me complete one print job, sometimes it won't. Sometimes unplugging it helps, but the light just comes back on. What could it be?
    I have the same problem. The check cartridge/check paper light comes on. I replaced the cartridge, check the paper, and press the button, and sometimes it will let me complete another print job, then it comes on again. Sometimes unplugging it helps. It's getting worse! What should I do?
  • Anonymous Apr 10, 2009
    Every light is flashing from the Check Paper/ Check Print Cartridge lights down to the On/Off button - I've checked for jammed paper and unplugged it but when I plug it back in it still blinks. The On/Off button doesn't even work.
  • lala15108 May 09, 2009
    ARGGHHHH! I have the exact same problem in that it sucks the paper halfway in, tells me there is a jam, and when I push the blinking button it shoots the paper out and draws another one in halfway. I have uninstalled/reinstalled, unplugged for a while, everything with no positive result.
  • rosesnedker May 26, 2009
    EXACT SAME FRUSTRATING PROBLEM WHICH I HAVE NOT BEEN ABLE TO RESOLVE
tom19511
  • 1601 Answers
SOURCE: paper jam (missfeed) message when using the printer hp psc 1510 all-in-one
HP's answer to your question.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu00697&lc=en&cc=us&dlc=en&product=428800&lang=en
Posted on Nov 09, 2007
squipps
  • 204 Answers
SOURCE: HP PSC 1510
Usually in the instruction book or under "help" when you open your Printer under Control panel /Printer Properties there is a section that deal in flashing lights on the printer.
This will help in finding out what area the real problem is in...sounds like a paper jam or feed problem.
Posted on Feb 05, 2008
pagebor
  • 2785 Answers
SOURCE: hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Posted on Apr 04, 2008
  • 3422 Answers
SOURCE: hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Posted on Jun 18, 2008
Ajkill
  • 2035 Answers
SOURCE: paper feed problems hp PSC 1510
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Oct 17, 2008
I can't turn off my printer, power button light and all other lights are flashing; it is not 1. paper jam 2. carrage jam 3. no problem with the ink what can i do.?
Is it sure that you have switched off all wiring including printer cable?
If not than switch off from main power supply and restart computer.
Sep 23, 2010 | HP PSC 1510 All-In-One InkJet Printer
The "check paper and check cartridge" light flashes and "Copies" says "E"
Check Paper/Check Print Cartridge Indicates the need to:
* Load paper
* Remove a paper jam
* Reinsert the print cartridge
* Replace the print cartridge
* Close the print carriage access door
Please perform the steps provided in the following web link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00476294&cc=uk&lc=en&dlc=en&product=428800
:) Dr Tony
Apr 15, 2010 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 keeps coming up with a misfeed
There may be a very small jam in the printer. Also, test with a different **** of paper. Put in one sheet to test.
Jun 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 ALL IN ONE
salut ROSENEDKER !
demonte entierement ton hp psc 1510 entierement et regarde du cote droit a la station de nettoyage;il ya une petite target qui doit etre cassee du cote haut ou bas . je dis bien cette target se trouve au bout du bloc des rouleau avance papier avec un ressort de rapel accrocher dessus . Merci et bonne chance
May 26, 2009 | HP PSC 1510 All-In-One InkJet Printer
Everytime i turn on my hp psc 1510 printer the check paper light flashes and it half gobbles up a sheet of paper then jams. also when i open the front flap to check cartridge installation is correct the...
clean its roller and service other part with clean cotton.
or it may that ejector clip of printer causes this.
when paper prints and it travel outwards then there are ejectors that pushes it out .sometimes that clips bend inside and not allow paper to come out.
regards,
Aug 14, 2008 | HP Computers & Internet
Won't print - just flashes it's lights at me!
I tried what phrek said (" Pressing the flashing buttons simultaneously, evokes the printer to spit out an internal diagnostic page ..."), but after the diagnostic page printed out the printer worked fine again.
Thanks for the help, and hopefully things work out for the rest of you as well.
Aug 06, 2008 | HP PSC 1510 All-In-One InkJet Printer
PAPER JAM THAT REALLY DOESN'T EXIST
make sure the back cover (black panel) is fully closed. If it is, remove the panel and shake gently to make sure nothing has fallen inside.
Mar 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510
Oct 04, 2007 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 1510 All-In-One InkJet Printer Logo
1,146 people viewed this question
Seeker5211
Seeker5211
