Question about Acer Aspire One PC Notebook
Screen dead after restart from hyber
Screen is dead after restart my acer one from a hyber, because battery is low. there is no signal of HD works, but fans works normally as if the laptop wants to start again and again. Tried removing battery, also pushing on button but nothing. need help, thxs.
  • monra387 Feb 20, 2009
    uaaahh....thanks anyway
  • RescueTechLA
    RescueTechLA May 11, 2010
    Try removing the hard drive to see if the computer will start up. I'd also reseat the memory as well. Post back so we can troubleshoot the exact cause.
    Scholar:
  • 53 Answers
I see these problems every day its a bad mother board we repair laptop every day with the same problems it is in fact a common problem with the acer laptops there is a chip set intergrated on the board that goes bad it runs hot and after a while they finally fail and what you see happening is the results.Sorry to bear bad news. after awhile it will quit powering at all thats the total failure of the chip.
Posted on Feb 20, 2009
Completely dead acer chromebook..working fine on battery when plugged in died
So did you unplug the power supply and try to restart it? When you plugged the power supply in did the power light come on on the power supply showing it was working? Blue light usually.
Sep 23, 2016 | Acer Computers & Internet
The WiFi keeps turning itself on. I turn it off and it turns itself back on ..
Why would you turn it off unless you are using another wifi adapter?
Most computers are set up to start the wifi when restarting the computer as default. If you don't want it on, don't restart the computer. I never restart mine, I just put it to sleep. It is dormant until you click something to make it wake. Nothing is working while asleep or hyberated. Perfectly safe, (but turn off the mouse it may wake with vibration of walking across the room).
Oct 25, 2014 | Computers & Internet
Acer Veriton 6900 Desktop says no signal and the screen turns off. The towers power light stays on but the fan isn't running.
Change the power supply and restart your pc. This will happen when the power supply has gone bad. It sends power to low voltage items but not the needed voltage to power the system on.
Good Luck
C2Solutions
Feb 14, 2012 | Acer Veriton 6900 PC Desktop
As i turned on my ACER ASPIRE M1461 desktop, the screen turned blue stating that it need to auto restart because it detected some errors and the hard disk was damaged , then it restarted but the bigger...
Your computer is not POSTing anymore. It has failed the Power On Self Test and is therefore not sending a signal to your monitor.
See my published guides in this regard, it is entitled
My Computer is not turning on!!! Is it dead!!! No POST!!!
How do I reset my BIOS/CMOS to defaults?
How to Remove the Side Panels of My Computer Chassis!!!
Hopefully the problem is due to a loose connection.
Take care!
damnor01
Apr 27, 2011 | Acer Aspire M3400B2072 PC Desktop
Acer Ferrari 4000 power up with blank screen, no
If you cannot "press DELETE to enter setup", then it's the motherboard, or the battery, or the AC power-supply that has the problem.
Since it's likely that at least one of the battery and the power-supply are working, it's probably the motherboard (or the CPU on the motherboard) that is failing.
Take the computer to a qualified technician.
Replacing the CPU is possible, and is not very expensive.
Replacing the motherboard is possible, but is very expensive
(a few hundred dollars for a replacement motherboard, plus $100 for the technician's time to disassemble/replace/reassemble).
The only "good" news is that your files on your disk-drive probably are intact, and can be read and transferred to a new computer.
Of course, you can try to sell the "dead" computer on eBay, so that somebody else can "frankenstein" your computer with their computer, to combine two dead computers into one working one.
Nov 11, 2009 | Acer Computers & Internet
HTC Touch HD restart problem
Check the battery connection, if the battery is loose/moves around when you touch it with your finger, try putting a piece of paper on top, or the side, or which ever way it moves. So the battery will still touch the battery contacts. If this isn't the case, try doing a hard reset. Go to start>settings>system>clear storage. (It's like this in my htc diamond, not sure about the touch HD, but should be same) which will erase all data/contacts. Make sure you sync your contacts to your pc to save them!
Feb 26, 2009 | HTC Touch HD Smartphone
No signal prob...
some issue have to make sure
1) check battery charging indicate light on(yellow)
2) check AC adapter and DC jack connection if no bettery charging
3) check power on from battery or AC adapter that situation is same or not
4) take away HD DVD and change memory
5) plug extenal monitor
if no any thing show on the screen, you have to send to repair by the specialist.
Sep 27, 2008 | Acer Aspire 3100-1405 Notebook
Acer LCD TV screen burn.
Burn in unfortunatly is permanant. It damages the liquid crystals that produce the image.
Mar 08, 2008 | Televison & Video
Acer Aspire One  PC Notebook Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
