Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
Ge profile notice: a problem has been detected with this unit
Washing maching unit, get this error message when I plug the unit in after 60 minutes. was told that the board is bad from a tech over the phone. can anyone confirm?
thanks
  • Donna Despain
    Donna Despain Mar 09, 2009
    washer was fine but next morning put load of clothes into wash came up code a problem has been detected with this unit can anyone help
  • Anonymous Apr 06, 2009
    exact same thing.. waiting on reason/solution.
Hello: I have a its a GE PROFILE WPGT9350 washer and i have that pop up when i push power button what can i do if you can help this missg "Notice A problem has been detected with this unit if you can tell me how to get to Service Mode Diagnostics" thanks my email is mnunocortes@hotmail.com Actually I have tried unplugging it and letting it rest and plugging it back in, same message. Thanks anything can help
Posted on Mar 05, 2011
My washer error message unit detect a problem
The most common solution for this message is to turn the machine OFF and then ON. If the error resets, you are done.
However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
  1. Clear the ERROR from the screen: Press and hold the MY CYCLES and BACK buttons simultaneously for 3 seconds. The control will display any recorded errors. Please write down what error codes are shown on your screen in case service is needed. If a MORE icon is displayed on the screen, press MORE to list additional errors. When the EXIT button appears, press EXIT.
  2. Remove Power: Follow the onscreen instructions to remove power (unplug unit) and then immediately plug unit back in.
  3. Clear Setup Mode: After power is restored, a setup screen that begins with "Congratulations..." will be shown. DO NOT PRESS the OK button shown at the bottom of the screen. Press the START/STOP and POWER buttons simultaneously until the Home Screen is displayed. Your unit is ready to function normally.
Mar 02, 2015 | GE Profile WPRE6100G Top Load Washer
My last load had three minutes left of spinning and I stopped washer to take clothes out. When I added another load a message came on scsreen that said "Notice! A problem has been detected with this...
Since the program was interuppted while it was running it was possible that the processor in the main controller unit has an error and so the output had hung up.
Hence you can remove the plug and allow the processor to reset, press down the panel play /stop button and after about an hour plug back to check .
The processor should normally reset and work normally unless there is a fault in the controller unit.
Aug 31, 2011 | GE WPGT9350C Top Load Washer
My ge profile harmony washing machine has a message that says "a problem has been detected with this unit."
Washers - Harmony Washer Error Message or Code
The Harmony washer electronics can automatically determine if problems exist with the machine. Sometimes an error code can also be present because of things the machine cannot control: like changes in house voltage, water pressure, or temperature.
"A problem has been detected with this unit" will be displayed on the screen.
The most common solution for this message is to turn the machine OFF and then ON. However, this message will sometimes cause the control to stop the machine from working. With this type of error, the control panel will need to be reset. The following steps will allow you to reset your control.
Solution:
GOOD LUCK. TIMOTHY DO 714-334-1998
Aug 04, 2010 | GE Washing Machines
Have a message on GE Profile Harmony washer that say " a problem has been detected with the unit" help?
Solution:
Jan 15, 2010 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
Wont run
Aug 19, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Error message only prior to the rinse cycle,not filling correctl
The cold water solenoid valve seems to have failed on you. They're easy to replace and can be purchased at any appliance parts company
Jun 15, 2009 | GE Dryers
Won't continue cycle the message is ''Notice'' a problem has been detected with this unit.
Press and hold the my cycles button and the back button simultaneously for 3 seconds. This will reset the control panel and let you see any stored errors.
Mar 13, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Notice a problem has detected with this unit
If the home screen is not displayed press home then help. Then press my cycles and back together for 3 seconds.  Read what its says and then turn the power off then back on. It should be ready to go!
Nov 13, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
A problem has been detected with this unit i need know how to enter my Service Mode Diagnostics
I'll email you a few pages out of a service manual for a WPGT9360 (closest I could find to your model number) hope this helps.
Nov 12, 2008 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
1,526 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
