Question about Radio Shack Pro-83 Scanner
I followed the manual to wipe out every freq on my scanner (Pro 83 compact radio shack). The way it tells you is if you are having problems, you wipe it out then you can bring your freq back. I want to completely reprogram it. It was my Dad's and it is all messed up and I want to put the freq in correctly. Please, tell me how to wipe it out then manually put them in one by one. Thank You
    President:
  • 2,761 Answers
Just select the channel you want to reprogram and enter the new frequency.. It will overwrite (replace) the old frequency.
Posted on Aug 09, 2009
Police radio scanner frequencies for los banos, ca.
Here you go.Pick your state then your county and it'll bring up all the available freq's for your county.
http://www.radioreference.com/apps/db
May 04, 2014 | Radio Shack Pro-83 Scanner
How do i reset radio shack pro 83 scanner back to factory settings
With the scanner off, press and hold the 2, 9, and HOLD keys. While still holding them down, power on the scanner. Continue to hold the 2, 9, and HOLD keys until the display says CLEAR.
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 19, 2010 | Radio Shack Pro-84 Handheld Scanner
Problem with PRO-2066 scanner not receiving local 800mhz Motorola trunk system II. It does trunk with the current data channels used (showing the ---- line) but I only hear transmissions on freqs ending...
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Aug 21, 2017 | Radio Shack Pro-97 Handheld Scanner
Freqs
Your scanner has somehow gotten out of alignment, and there's no way to fix it with just a screwdriver. Your best bet for repair is your local Radio Shack. If they can't do the repair they should be able to refer you to a local, or they can ship it off for alignment.
Bill B
Mar 08, 2010 | Radio Shack Pro-95 Handheld Scanner
Hand held pro 83 scanner
http://support.radioshack.com/manuals/ome20-501.pdf
May 30, 2009 | Radio Shack Pro-82 Scanner
Frequences
if you take it down to your local radioshack they will usually add freq's for you.
Jan 18, 2009 | Radio Shack Pro-97 Handheld Scanner
Program
Radio Shack has a manual for the PRO-83 scanner online in Pdf format. It worked great for me and I honsetly could not tell any difference in the PRO-83 and my PRO-84 !! It worked great for me and I had my scanner set up and working very quickly!! Hope this helps you all as much as it did me.. the manual is for the PRO-83 200 Channel compact scanner w/signal stalker search and lighted keypad.
Hopes this helps you all !!
Aug 21, 2007 | Radio Shack Pro-84 Handheld Scanner
1000 scanner radio shack
press the manual button a few times, and make sure there are actually some freq. programmed into the unit. if there are freq other than 000.000000 in there, press the s/s (lockout) button and see if this unlocks the frequencies to allow them to be scanned.
Aug 19, 2007 | Radio Shack Pro-94 Scanner
Radio Shack Pro-83 Scanner Logo
181 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
