Question about Rockford Fosgate P3001 Car Audio Amplifier
My amp has no power but everything works on it i just pulled it out of another vehical
  • Michael Robideau May 11, 2010
    WHAT WORKS ON IT IF THERE IS NO POWER(JUST THE POWER LIGHTS I NEED A LITTLE MORE I AM SURE WE CAN FIX THIS.
    Problem Solver:
  • 11 Answers
SAND THE PAINT AWAY FROM WHERE EVER THE GROUND WIRE IS TOUCHING THE BODY OF THE CAR. ALSO CHECK UR REMOTE WIRE ON THE AMP. IF THERE IS NO REMOTE WIRE ON STEREO THEN JUST RUN THE REMOTE WIRE FROM AMP TO THE POWER ON THE AMP
Posted on Feb 24, 2009
CLarke 130 en everything works Great except when I select # 4 on the heat then it won't feed when the trigger is pulled?
i put a new motor on the welder an i have 9 to 12 vote coming to the motor but the motor wont run all works but the motor
Mar 14, 2012 | Clarke Power Products Clarke 130EN...
The code 0p000 keeps coming up when we use a scanner what can this be? Please help
WITH OBD SCANNERS THEY WORK THRU THE CARS COMPUTER AND WILL NOT WORK ON SOME OF THE OTHER AREAS OF THE VEHICAL, YOUR CODE 0P000 IS SHOWING
THE POWER TRAIN PARTS OF THE VEHICAL WHICH COULD BE THE TRANSMISSION.
YOU WILL HAVE TO TAKE THE VEHICAL TO A DEALER FOR A TRUE SCAN. I HAVE AN
OBD II SCANNER ALSO AND THIS IS ONE OF THE DOWN FALLS TO THE SCANNERS
May 20, 2011 | Mitsubishi Lancer Cars & Trucks
I am not getting power off of my trailer plug for my drivers side directional and brake light but it works on the truck. There is no power at the terminal or the wiring too the back of the trailer plug....
Id say your pig tail to the trailor is having high resistance or a wire is cracked, Follow the pigtail under bumper, It plugs into main harness, Disconnect and look for damage or a dry white powder. If everything else works as you say? And your positive the vehical being toweds lighting works on another vehical? than the pig tail is bad, replace at any local parts store
Jun 13, 2010 | 2004 Dodge Ram 2500
The gears are not shifting. Vehical starts runs good but when you drive it does not seem to want to shift out of 1st? We got the jeep stuck and hydro locked the vehical. We were not able to get it started...
you may want to do a bg trany service also,because just dropping the pan wont get the water out of the cooler or lines or converter,also may want to check the transfer case and frt and rear diffs for water,
Apr 09, 2010 | 1999 Jeep Cherokee
No power to fuel pump
Hello , have you checked the vehicals ECU ? Maybe get a used one off Ebay and swap it and it will either work , or tell you its not the ECU. Do you have power coming into the vehical anywhere? Do you have voltage going to the ECU from the batt? Thank you , Quinn
Aug 21, 2009 | 1990 Dodge Dakota
I have manual seats and i am thinking of changing
Going to a junkyard quiz the operator about cars or trucks that they have that may have all the parts you need used. The cost of new parts in this area are very expensive and you can possibly find everthing you need in one vehical. Once the parts are found your not done as the wiring in your vehical may not have everything you need as the new seats may be heated and your vehical may not suport it. Alldata for your car is inexpensive and will save you from having to figure it all out for yourself. An experienced Junkyardman may know what you need and even reconmend a good mechanic to make everything work as they know their customers and they know who the resonable pros are and how to find them. Good luck,Staying with the same brand and nearly the same model may get you bolts right up if your car was made for the option that you want. John
Aug 10, 2009 | Equinox (210120)
Problems turning on
Pull your lead power wire right off the positive term. on your battery
Dec 31, 2008 | Kicker IX404 Car Audio Amplifier
Smoking Amp
yes let me see the pics my email is troublerst@hotmail.com
Jan 23, 2007 | JBL GTQ190 AUTOMOTIVE POWER AMPLIFIER Car...
Rockford Fosgate P3001 Car Audio Amplifier Logo
353 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
