Question about Kenmore Elite 45986 Front Load Washer
"F" code then "dl" flashes, won't continue
Last week had repain man "fix" "F11" that was flashing, stated we needed to clean the drain. Now, one week later, 3 min after cycle started, began beeping, flashing "F" and "dl". "DL" not in my manual??? Any ideas? It is 2030 on Thursday night with wet clothes in the machine!! Help!!
  • simonfamily4 Feb 20, 2009
    I have the same problem and I have called the Technical support to find out if there is a way to get the clothes out of the machine. I have been told there isn't a way. "dl" I was told means door locked, and Fll is an errror of the control panel.. I guess what that means is the control panel went bad. I would like to get my wet clothes out of the washer. Any suggestions out there???
  • Anonymous Mar 27, 2014
    DL flashing, how do I clean the drain?
  • 15,935 Answers
"F11" is a Serial Communications error between the Central Control Unit (CCU) and Motor Control Unit (MCU). The CCU is the main computer for the washer and is located directly behind the wash tub. The MCU is the Drive Motor Control board and is located in the rear of the washer adjacent to the Drive Motor on the left-hand side (facing from the rear with the back panel removed). The wiring harness can also cause the error, but it is not as common a problem.
Whirlpool is the manufacturer of both model washers and recommends the following troubleshooting advice. Remove the top panel of the washer by removing the three screws holding it in place in the rear. Once the screws are removed, the panel slides back, then off. Remove the rear panel of the washer for access to the drive motor and MCU. Now check the following:
- Check the wire harness connections between the CCU, the MCU and Drive Motor. Make sure all connections are attached and making good contact. Check for any broken wires or connector pins.
- Check the Drive Motor to see if it free spins and that the belt is still attached and not slipping. If the motor is seized, replace it. If the belt is broken or worn, replace it as well.
- Check the MCU. Connector 1 is the Serial Communications Link between the MCU and CCU. Connector 2 is the connector to the drive motor. Resistance checks across pins 1, 2, & 3 are the motor windings. Connector 3 is the power supply - 120VAC should be read across pins 1 and 2 with the door in the locked position. NOTE: The connectors are read 1, 2, and 3 from the bottom to the top with the MCU installed.
- Check the CCU. Verify connectors 7 and 11 are properly installed. Facing from the front of the washer, connector 7 is the 4th connector from the RIGHT along the front. This is MCU Power. Connector 11 is the Serial Communications link from the CCU to the MCU and is located along the left hand side of the CCU (the connectors are numbered 11 through 14 back to front).
- Check the Drive Motor. Remove the connector and perform resistance checks on the motor connector pins. Readings across pins 1 to 2, 2 to 3 and 1 to 3 should read 6 ohms.
In most cases this is an indication of a failed CCU. This is an easy repair that the average do-it-yourselfer can accomplish on their own. If the washer is still under a warranty, parts and labor would be covered. With no warranty, a replacement parts will vary in price depending on where you get them. There are several good websites available that you can order parts on line and have shipped directly to you.
NOTE: Remove all the connectors from the CCU ONE AT A TIME and reconnect to see if the error code goes away BEFORE you decide to purchase a new one. It is not common, but sometimes a flaky connection can generate error codes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
HE4t 45981 Washer dl f and F11
The DL F error is saying that the door lock mechanism is faulty and will need to be replaced.
Mar 05, 2012 | Washing Machines
F11 code flashing-washer stops
hi!!!!
try to unplug it end then check the control timer if it is broken !!!!
or open it if you know and fix it may be the spring that pull back the pause botton
might be broken go check it?
Sep 19, 2008 | Kenmore Elite 45986 Front Load Washer
Just new out of the box. Will wash ok but won,t release water, then error code F11 appears with all lights flashing.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
Dec 31, 2010 | Indesit Washing Machines
F11 and DL failure codes
The F11 error indicates a communications error between the CCU (Central Control Unit) and the MCU (Motor Control Unit). Check the wiring harness and connections at both the CCU and MCU. Unplug them and check for corrosion on the terminals / pins, clean them if necessary then reconnect them securely. As there is a D11 error as well it indicates a problem with the door lock relay, faulty hall sensor, faulty CCU or faulty MCU. If you still have the problem then call in a repair man to fix it.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washer beeps and flases f dl
it probably flashes also f11....to correct that problem , you must replace CCU board (upper board) and latch assembly...
F11: CCU board
FDL: latch problem
Jul 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I HANE A WHIRLPOOL FROUNT LOADER THAT KEEPS FLASHING A CODE F11
"f11" error will be a bad ccu(central control unit) replace and you should be good to go.
May 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I am getting an DL F code on my front loader
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
Model 45981 HE4t Washer
The code "dl" stands for "Door Lock". This was a problem with my machine also. Check to make sure you are only using "HE" type of detergent. In the manual it states that using other detergents than high efficiency will cause computer board miscues.
Unplug the machine for a day or less, then try again. This worked for me for a while. It finally failed (I was using detergents other than all HE) and a repair man reset the washer. This happened last month (June, 08) and now I only use HE and the machine works great.
Jul 08, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
