Question about ASUS Eee PC 900 Notebook
Will mot boot up
My computer charger had a bad connection in the first place. Anyway i went in my room and my dog accidentally yanked the cord causing it to lose the connection. I turned it back on and it worked fine then it lost the connection again. Thats when it didn't come back on. I noticed that the green light that blinks when it is turned off does not blink. What to do. It will turn on and off but doesn't show the screen.
  • IevaB Mar 14, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
    mso-para-margin:0cm;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    I have similar problem with asus eee 901. I've just bought
    it. It had linux, but it was changed into windows xp. Since it had been fully
    charged only once I was using it on battery and setting it up with new
    programs. The battery discharged and it went on stand-by. I woke it up and
    waited until battery was dead. That started charging it and turned the pc on,
    but the screen went white and stayed that way for couple of seconds. Moments
    latter it turned black and now it doesn’t seem to work.
    What could have happened? What can I do?
    When i try to turn the PC on power indicator is lit, battery indicator is
    working normally (it is charging right now) and the ssd indicator is lit all
    the time.
  • RescueTechLA
    RescueTechLA May 11, 2010
    Is the power jack on your laptop loose now? Does the computer still work off battery power alone?
    Scholar:
  • 150 Answers
The cord is probably ruined either by the dog or by folding the cable when you pack it up. The charger brick itself is probably fine but you will need to buy a new charger cable. Contact ASUS to determine how much that will cost.
Please rate, Thanks!
Posted on Feb 27, 2009
My phone was working place it on charger went back and the phone is dead will not come on
The same thing happened to me. It's probably your charger porter. did you somewhat yank the charger out sometime or did it fall of a table or something and the charger yanked itself out when it fell (if it fell). If that's the problem, try putting the charger in the phone & hold the charger up, worked for me. You could also try a different charger or buy a battery charger like I did. There's the link if of the battery charger if needed. I hope this helps!
http://onepluswireless.com/products/universal-external-cell-phone-battery-charger-charges-most-brand-phone-batteries
Dec 03, 2015 | Blu Studio 5.0 Mobile Phone
My Auvio iPhone4 charger was accidentally dipped in some moldy gunk in my child's room i clean most of it out but it still will not charge properly how do i fix it?
phone chargers ( as long as you get the correct connection for the phone ) are generic
take the charger to places like jaycar and get a new one
go on line to e bay and see what is available
Apr 21, 2015 | Cell Phones
The labtop doesnt boot when the charger is placed in and it also goes of when the charger is put in
Is the AC cord the original? Has it been damaged? Have you tried another AC cord, with the EXACT same power specs? It may be a damaged AC jack. Sometimes a pull or tug on the cord while plugged in will loosen the connection. If you wiggle the cord at the jack plug does it cause the charge LED to blink? Does the computer work on battery?
Nov 28, 2013 | Toshiba Satellite A305-S6863 Laptop
Telefunken mr701 diagram
follow this steps and fix it. God bless you
Bad cable connection
Check the USB cable for damage and dirt, especially at the ends. Then try using the wall charger, as this will provide greater power input than the computer/USB.
Broken charger or USB cord
Try using different chargers to see if you may have a problem with your charger or cord.
Obstructed/bad dock connector
Inspect the 30-pin dock connector at the bottom of the iPhone for dirt, lint, and damaged pins. Clean out the dock connector very carefully with a tooth pick or soft toothbrush. If the dock connector is broken, you will have to replace it.
Jul 11, 2013 | Cell Phones
MH-25 is not charging the battery
Check the cords and make sure to disconnect and then reconnect the cords. Try the charger if nothing then try replacing the battery. If the battery is bad the charger will not work. If the battery is replaced and will not charge then replace the charger.
Mar 26, 2013 | Nikon MH-25 Charger NIKON
No power
Try another outlet, cord/charger, with the EXACT same power specs. Has the cord plug been pulled while pluged in damaging the AC jack? Does the computer boot on battery power?
Feb 20, 2013 | MSI A6200-059US Laptop
My acer aspire one notebook won't boot up.
Is the new cord/charger/transformer the EXACT same power specs? When your "dog ate your charger", it may have shorted out something in the Laptop? Was it plugged it when your dog ate it?
Jan 16, 2013 | Acer Aspire One PC Notebook
My computer was working fine last night. When I was online, the dogs came running thru the room and pulled the cord out, from the wall AND the netbook. I closed the computer and this morning, nothing. ...
Try and take the battery out and leave the machine connected to the AC power and see if it will boot up without the battery. You may have shorted the battery out .
Apr 19, 2011 | Acer Aspire One Netbook 8.9" Notebook
Dell Inspiron B130 wont boot
First remove the battery from the PC! Leave it off for a short period of time! about 2min. This allows the computer to erase anything in temporary memory. Place the battery back onto th PC and try to boot it up. The other thing you can do is boot the pc up with just the power cord in place. See if it boots just from the power cord. Sometime the batteries from dell causes the whole entire PC to become unresponsive.
Nov 26, 2007 | Dell Inspiron B130 Notebook
ASUS Eee PC 900 Notebook Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
