Question about Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 shutting down
I have a Panasonic Toughbook CF-51. It fell off the couch & now it begins to boot up and within 30 seconds shuts down. I've been told it needs an inverter board, but can't find one anywhere online. Anyone familiar with this issue? Thanks for any help. Sue, FL
  • 1 more comment
  • ph0942 Feb 20, 2009
    Hi, thanks for the response. Actually, nothing comes up on the screen. the battery light is lit. I press the power button & the indicator lights come up for perhaps 30-40 seconds, then all lights go out. Why would the issue be the inverter board? the computer doesn't seem to power up? thanks
  • ph0942 Jul 30, 2009
    Hi RescueTechLA,
    Actually, the power board lights are now staying on but the LCD screen is very, very dim. I can't seem to find a replacement inverter board, especially not on panasonic.com!
  • RescueTechLA
    RescueTechLA May 11, 2010
    Sue,
    The inverter board controls the brightness of your lcd. Think of it as the power board for the light bulb inside your lcd. If your computer turns on but then all of a sudden gets dim (but you can still see something very dim on the lcd) then it's probably related to either the lcd backlight or the inverter board.
    Can you give me some more details? Does it try to boot up, do you get a windows screen, what does the screen say exactly?
    President:
  • 2,653 Answers
Sue, it's not the inverter board. People who don't really know much about laptops will often diagnose them incorrectly, especially computer repair shops. The problem you're experiencing is most likely related to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
Posted on Feb 20, 2009
    Novelist:
    Scholar:
  • Panasonic Expert
  • 120 Answers
Laptops Shut-Down when the unit Over-Heats.
Panasonic Toughbooks are no exception.
If the FAN is potentially Blocked with DUST or
the Fall caused the FAN to FAIL, then that would explain
the Shut-Down. Try blowing out the dust from the
back or rear-side of the Toughbook. Please also take out
the removable CD-ROM drive and the battery pack.
This will allow the dust to escape by the cavities or holes
created when there is no optical drive or battery pack.
Use a compressor instead of those cans of compressed air.
Blow also through the cavities. Use short bursts of air rather
long prolonged air blasts.
Finally, if this does not work, you should be able to purchase
a replacement CF51 (without Hard Drive or Battery Pack)
for less than $75 and then transfer all the removable parts
from the old unit to the replacement unit.
Good Luck.
Regards, Richard
Panasonic Toughbook Authorized Dealer since 1989
Posted on Feb 08, 2016
3 Suggested Answers
  • 53 Answers
SOURCE: I have a Panasonic Toughbook CF-51. It fell off
i repair laptop every day and i have never seen and inverter board shut down the computer.in less it was total shorted. it sounds more like the fall my have damaged the hard drive. if a the drive wont spin it will cause the laptop to power down cause the little motor will over heat in a matter of seconds.if the laptop was on when it fell then its more than lickly the drive.
DosHog
  • 168 Answers
SOURCE: Hi. I have a Panasonic Toughbook CF-51 that fell
I hope I am not stating the obvious by suggesting Panasonic's website.
Posted on Jul 29, 2009
How do I reset the bios Password on a Panasonic Cf-51
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Oct 10, 2016 | Panasonic Toughbook CF-51 Notebook
Cf-30 disable touchscreen
On all Panasonic Toughbook Notebooks,
you must get into the BIOS by pressing
the F2 Function key when you turn on the
Toughbook as it is booting. Press F2 repeatedly.
This must be done in the 1-2 seconds before
Windows starts to load. Then you will see
Touchscreen usually on the 2nd page with the
word "Enable". Simply select enable and press
"Enter" and the choice between enable and disable
will appear. Then select "Disable" with the cursor
and then press Enter. Finally you need to
"Save and Exit" the changes in the BIOS.
That is it. Good Luck to you.
Regards,
Richard - Montreal Based
Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
Panasonic toughbook cf-51 drivers audio
The audio or "Sound Drivers" for the Panasonic
Toughbook CF51 are located at:
http://pc-dl.panasonic.co.jp/itn/drivers/d_menu_en.html
Please remember to choose your operating system
and click on the "Download Now" button located at the
right hand side.
Gracias and de nada.
Good Luck. Buenas suerte
Regards,
Panasonic Canada Toughbook Dealer since 1989
Aug 29, 2012 | Panasonic Toughbook CF-51 Notebook
I need an owners manual for a Panasonic CF-51
ALL Drivers and Owners Manuals for
ALL Panasonic Toughbook Models are
located at the following website:
Make sure to select "Manual" on the menu on the
left hand side, fourth down from the top.
Good Luck!
Regards,
Panasonic Canada Toughbook Authorized Dealer since 1989
May 30, 2012 | Panasonic Toughbook CF-51 Notebook
The lapstop does not boot up. the MP indicator
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Also listen carefully for any beep sounds.
Mar 03, 2010 | Panasonic Toughbook CF-51 Notebook
Jul 29, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic CF 51 keeps shutting down
At what point does it shut down? Normally thats caused by heat and/or could be viruses. I would blow out all the ports with compressed air. Does it get into windows before it shuts down?
Jul 24, 2009 | Panasonic Toughbook CF-51 Notebook
Need a motherboard for a cf 51. mine is a dl3up1481aaa. That number cannot be found. will anyother work in it's place.
There's one on ebay right now ! check it out fast.
http://cgi.ebay.com/Panasonic-Toughbook-CF-51-Motherboard-DL3UP1379AAA_W0QQitemZ360164329640QQcmdZViewItemQQimsxZ20090621?IMSfp=TL090621142002r28025
Jul 14, 2009 | Panasonic Toughbook CF-51 Notebook
Feb 20, 2009 | Panasonic Computers & Internet
Panasonic Toughbook CF-51 Notebook Logo
600 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
