Question about Kenmore 43142 Front Load Washer
Kenmore washer won't start.
After pushing the start button, the light just flashes and nothing happens. I suspect the door is not locking. Any way to reset it?
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Regards
John
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
see this causes and fix it. God bless you
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
He3 washer will not start. The lights on the
you probably broke the door switch and the machine thinks the door is open. little piece on top of the lock catch. need to change the door switch
Feb 05, 2010 | Kenmore Elite 45986 Front Load Washer
Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
Jun 24, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore HE3t lights up ,won't start
sounds like a door lock/latch issue, its not recognizing your closing door so its not starting unit
Feb 28, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore 43142 Front Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
