Question about RCA F32645 32" TV
Screen turned red
My tv screen just turned red while whatching it
  • 75 Answers
There is three resistors on the crt board that is the board that plugs onto the back of the picture tube they are biger than the others one of them could of gone out of spec that will couse this kind of problem also three transistors on the same board that one could be bad need to check them out. If you do not know much about electronices I would probley take to a shop for repair . Would not want anyone to get hurt. Be sure to unplug tv before you do anything on the inside still even if unpluged could have high voltage in set.
Posted on Feb 20, 2009
My pictur on my tv looks like it is snowing how can I fix it
try to watch a movie that doesnt contain snowing...
If you mean white pixels for no reason on the screen while whatching the tv it can be caused by unstable power, or tv signal.
try to remove tv cable, then replug it so the picture will clear
Apr 13, 2013 | Televison & Video
Vizio 37 hdtv problem, blue screen w/ no signal displayed then shuts down in about 20 seconds
The problem is the main digital board. It does not have a reset button.
Oct 25, 2017 | Vizio VX37L Television
Three green lights and two orange light blinking
One of them "LAMP" LED light indication is blinking?Yes,mean ur tv projection lamp life is over.Tv projection lamp been inside this tv like 1 1/2 or 2 year and tv been on and whatches like 4 or 5 hours of tv daily?Yes,to all these mean ur tv projection lamp require replacing.
Jan 13, 2011 | Vivitek V37655 56" DLP TV
The xbox shuts off stops working
This could be the power brick overheating, next time this happens look at the light on the power brick, if its red thats your problem,clean any dust away from the vents and make sure that it has enough ventilation.
If this is not the case, I will need more info, any lights or fuzzy screen etc.
Remember thumbs up if this helps.
Jan 29, 2010 | Microsoft Xbox 360 Console
Wheni turn on my tv ive got a blue outline on what ever i whatch
The blue outline is a convergence problem. Depending on the brand of tv you have there are adjustments to fix that. If the adjustments wont work then the convergence circuit will have to be repaired.
May 04, 2009 | Philips 55PW9363 55" Rear Projection...
Will not power on
There are 2 fuses on the back panels inside check these first. Best to have tech do if you are not familiar with the PC boards. Should cost only 20 bucks or less for sevice call. Whatch what he does & ckecks as to not get ripped off.
Mar 23, 2009 | Sharp 56DR650 56" Rear Projection HDTV
No digital sound coming out of our tv
Make sure the volume is turned up on your TV (obviously).
Also in the menu make sure that any options for audio/speaker mode on the BRAVIA are set to ON and not OFF.
Mike
Oct 31, 2007 | Televison & Video
Vscan voltages on LG Plasma
Are your sparkles mainly red pixels flashing randomly over the TV screen, especially over darker areas? If so your sparkles are I believe a discharge problem, and can be fixed with a firmware upgrade, which I think resets and corrects the voltage and removes the sparkles, which is caused by misfiring of the gases produced with plasma TV's. I have had my TV repaired with a firmware upgrade, which takes only 10-15 minutes and is reasonably cheap repair, and now the TV looks great, no more sparkles. Don't play around with the voltages let the pros fix it, also beware! leave this too long and it can become permanent, and need a new screen which is half the price of the a new TV.
Oct 15, 2007 | LG 42PX5D 42 in. Plasma HDTV
E79
hello Mostafa the E79 means : Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption. I whish this solution will solve your problem. MOHAMED AMINE
Aug 25, 2007 | Microsoft Xbox 360 Console
RCA F32645 32" TV Logo
46 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
