Toshiba spa40 or a40
I have a Toshiba spa40 laptop the battery is ok and the laptop will run on a charged battery or power supply but for some reason it will not charge the battery. is it a faulty fuse or conection on the motherboard that i can repair if so which one thanks
    Problem Solver:
  • 10 Answers
Check that the power supply is the correct one for the laptop, check that the power requirements of the laptop match up with what is being supplied by the power supply.
if the labels match, for Toshiba the usual supply voltage is 15VDC, if the supplied voltage is 1 volt below recommended the battery will not charge.
If all appears correct then check the output voltage with a multimeter it should read 15V (-0.25V +1V).
If the power supply is a bit low you'll need to buy a new or used one.
Posted on Feb 21, 2009
Toshiba satellite l300 not charging, doesnt work on the power supply
Try removing the battery completely and running it with the power supply connected. If that doesn't work, try borrowing a compatible power supply, or buy a universal one, and try with and without the battery connected.
The problem may be the power supply, in which case the battery won't charge and the laptop won't get any power.
Apr 06, 2011 | Toshiba Satellite Pro L300 Notebook
I WISH TO DOWNLAOD TOSHIBA LAPTOP DRIVERS FOR TOSHIBA SPA40
http://uk.computers.toshiba-europe.com/innovation/download_drivers_bios.jsp?service=UK
Jul 10, 2010 | Toshiba Satellite L355-S7811 Notebook
Toshiba satellite a40-s270 won't turn on
Either the power supply is not working or the battery has failed and will not hold a charge. If the laptop is 3 or more years old, the battery is the likely suspect.
Feb 12, 2010 | Toshiba Satellite A40-S270 Notebook
Will not charge
With both above posts above included I want to add my experience with 3 Toshibas.
1. The A75 series was very prone to the power supply becoming loose on the motherboard. Those who are moderately good at DIY projects can resolder this. There are good photos elsewhere to show how. A loose connector will cause the power LED on your computer to flicker, sometimes the machine will turn off, etc. because the AC supply is unpredictable. Unfortunately, Toshiba and others may sell you a NEW power supply, which then can give you a second, and different, problem. The new power supply may not produce enough AMPS for the A75
2. The A75 series is VERY energy hungry and must have a power supply of 19v and 6.3 AMPS. The amps is CRUCIAL. The newer Toshibas run on 3.4 amps and a replacement power supply of the wrong size will show a green LED for power, it will charge your Battery in the system off( i.e computer plugged in but turned off mode) but it will not allow windows to run, even though it will allow you into BIOS setup. This combination means you have to charge the battery in the OFF mode and then when the computer runs, it is actually running from the battery, not 120v AC. The battery then runs down and the sytm shuts off.
So look at the Toshiba Label on the bottom of your laptop and read the correct voltage and AMPS!!! The 6.3 AMP power supply is BIG (6.5x2.5x1.5 inches) and is available new online for about $27.00. This problem solved my power problems on both an A75-S2292 and an A25.
Good luck
Sep 28, 2009 | Toshiba Satellite A75-S229 Notebook
My Toshiba Satellite A30 laptop keeps switching off when charging. It works fine when on the battery but seems to overheat when I use it whilst charging the battery. Can you help ?
I would suggest that you try it with another AC adapter first, because it seems the adapter is faulty and therefore supplying more current into the laptop than necessary.
If it works perfectly with another AC Adapter, then you might just have to change your AC Adapter.
Hope it helps.
Jul 05, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Toshiba A205-S4577
Check your power settings. You might have it set to shut off after a certain time of non-use.
Sep 22, 2008 | Toshiba A205-S4577 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba satellite pro psa45e-007n1-en manual
Also, Is it "Toshiba Satellite" or "Toshiba Satellite Pro"?
Sep 14, 2008 | Toshiba P000392200 - Satellite A40, A45...
Toshiba sat 1410 power charging
Categorises exactly what is/not happening. Appreciate that you have reformatted the system. So what is the situation now.? Operating system in or not in? Switch on --screen lights up to POST yes /no Machine dead or alive- ie when switched on do fans/drives run ?[listen out for them] How do you know battery is OK or power supply to computer is good?
May 28, 2007 | Toshiba Satellite 1410-S173 Notebook
Computers & Internet Logo
348 people viewed this question
David Payne
David Payne
