Question about Hotpoint HSS25GFP Side by Side Refrigerator
Hotpoint ref'r icemaker does not work.
We can get water from the dispenser but no ice.I checked the inside for the shutoff lever. It is down but the icemaker still does not work. The ref''r is about 10 years old.
I defrosted the freezer, overnight. After turning it back on in the AM it worked.
Posted on Feb 21, 2009
It is a GE GSS25WGMC model. The green LED on the icemaker is on (not Blinking) When you call for ice, you hear the motor trying to turn, but the 2 prong lever that should turn the spiral in the ice...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Sep 18, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
No water in icemaker
Please click on the blue links which are underlined to get more info.
Here are the check's which you can do:
Goodluck..
Feb 19, 2008 | Frigidaire FRS26F4C Side by Side...
We have a TFH27PRSM WW refrig & ice maker which both cubes & crushes and water dispenser. We get water from the dispenser but no ice is made. The ice maker lever is down on "on" but the...
NOTE: This
Leo Ponder
imufo2
Sep 12, 2011 | Refrigerators
Water dispenser gradually went from full flow to no flow. No kinks in line. Filter is good. Lines going to the filter feel cold to the touch. Frig settings are on normal. Hotpoint 22.0 Cu. Ft....
NOTE: This
First I would check the fan in the freezer. Listen to see if it is running
http://www.applianceaid.com/procedures.html
I'm
Leo Ponder
imufo2
Sep 03, 2011 | Hotpoint-Ariston HSS22GFTWW (22.0 cu. ft.)...
I have a Whirlpool side by b side ref. with a water disprenser and ice maker problem. Model ED25RFXW03 The water dispenser hums, starts dispensing water then slows to a trickle. The water has been slowing...
NOTE: This
I'm
Leo Ponder
imufo2
Aug 21, 2011 | Whirlpool ED2FHGX Side by Side...
The water quit flowing to the water dispenser and the ice maker keeps freezing up between the ice drawer reservoir and the "tunnel" where the ice goes into the dispenser.
NOTE: This
I'm
Leo Ponder
imufo2
Aug 14, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water dispenser not working and icemaker not making ice
Make sure you have water to your inlet valve. If you do shutoff water to valve and have valve tested. Chances are the valve has gone bad since both water dispencer and icemaker cant get water.If you have any questions or this does not cure your problem please reply.
Aug 01, 2011 | Hotpoint Refrigerators
Icemaker will not stop dispensing ice
Can you confirm please does it dispense water by itself if you select water? have you tried lifting the ice maker stop lever by hand? At a guess from your fault description I'd say you need a new dispenser micro switch. at worst a new Ice maker unit inside freezer. cheers
Mar 26, 2009 | GE Refrigerators
Ice maker not working
The icemakers won't make ice if the temperature is not below a certain set point. Varies between manufacturers. Try making the temp colder.
Feb 01, 2008 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
128 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
