Question about Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness
Which fuse handles instrument panel and tail lights on ''98'' E150
Can I see a fuse panel diagram?
  • Anonymous Apr 01, 2009
    i went to autozone and asked them for the same thing and they told me they cant
  • Anonymous Mar 18, 2014
    I have changed an instrument panel from a HJ to a HZ and have no indicator lights
  • 55 Answers
WHEN YOU TAKE OFF THE COVER OF THE FUSE PANEL THERE SHOULD BE A FUSE DIAGRAM ON THE BACK COVER .OR WERE THE FUSES PLUG IN IT SHOULD SAY.....IF NOT TAKE OUT EACH FUSE ONE AT A TIME AND LOOK FOR A LITTLE BREAK IN THE FUSE WIRE.......OR GO TO AUTOZONE AND JUST LOOK AT THE REPAIR BOOK FOR THAT CAR OR JUST ASK THEM AT THE DESK THEY WILL LOOK IT UP ON THE COMPUTER GOOD LUCK
Posted on Feb 20, 2009
2 Suggested Answers
  • 1596 Answers
SOURCE: which fuse handles instrument panel and tail lights on ''98'' E150
Useualt Same one as PARK Lights
Posted on Jun 02, 2009
2003 Pontiac Vibe no tail lights, brake lights and turn signals work just fine. The dimmer switch does not dim the dash lights but does work the dome just fineand the lights for the Heat/AC are off.
The tail lights work off the headlight switch, and there is a fuse for the tail lights. Make sure the fuse is good, first, a 15 amp (blue) fuse in the instrument panel fuse block. Then, you might have a bad headlight switch.
So you DO have dash lights, they just don't dim from the dimmer switch? In the wiring diagram, there is a green wire from a "tail light relay" (in the "Junction Block-Right Instrument Panel") that carries power to all the exterior lamps, as well as having a splice to the Instrument Panel Cluster (illum. bulbs), and to the lamp dimmer, and to the radio bulb.
To do any further testing, you would need a voltmeter or a test light, so you could chase down this power loss. Good luck.
Oct 17, 2016 | 2003 Pontiac Vibe
Where is my ign fuse located on my car
Below dash instrument panel, R16 ignition relay
98 Ford Contour SE Fuse Box Map
Fuse Panel Layout Diagram Parts: passenger side air bag, heater blower, interior lighting, heater blower motor, parking lamp, interior lighting, electric mirror, clock, wiper motor, ignition, reverse voltage protection, rear window defrost, engine management system, instrument panel illumination, radio, wiper motor, power windows, ABS module, backup lamp, brake lamp, door lock, main light, cigar lighter, electric seats,
link below should be the same as yours, press the helpful button
http://www.autofuseboxdiagram.com/1342-98-ford-contour-se-fuse-box-diagram
Jan 30, 2016 | 1999 Ford Contour
Where is my ign fuse located on car
Jan 30, 2016 | Cars & Trucks
2000 Lexus LS400 Instrument panel fuse
It's more likely a fuse is blown, the tail lights are on the same fuse as the dash illumination, check the tail lights if they are not working replace the fuse marked 'tail' in the fuse panel on the inside at the left side of the dash under the cover. At the same time check the 'gauge' fuse', there is a fuse location diagram on the cover.
Apr 13, 2014 | 2000 Lexus LS 400
I replaced the instrument cluster & head light switch on my 2001 buick century and the instrument panel and tail lights still do not work, what else can I do
Check 20Amp LP Park Fuse in Underhood Fuse Block (mounted to right strut tower) Check 15Amp Tail Lic. Lamp Fuse In IP Fuse Block.
Mar 15, 2014 | Buick Cars & Trucks
I have a 98 chevy malibu. the tail lights, running lights and instrument lights do not work but head lights do
The good news is that all of these problems stem from the same source: the 15A PARK LPS fuse in the underhood wiring harness junction block. When you set the turn/headlamp/wiper switch to PARK, the park lamp relay in the junction block closes and power is applied to the front marker lamps and the park filament of the front park/turn lamps as well as the tail filaments of the rear tail/stop lamps.
As for the instrument lights, that same PARK LPS fuse applies power to the same turn/headlamp/wiper switch that, when set to PARK or HEAD applies power to the variable panel dimmer switch which lets you set the illumination level. Switch output is applied to the lamp dimmer module and module output passes through the 10A INST LAMPS fuse in the right I/P wiring harness junction block to the instrument lamps
Oct 13, 2012 | 1998 Chevrolet Malibu
98 chevy silverado:
There is a short in the electrical circuit that is protected by the fuse. If this fuse protects the tail lamps then there is s short in the wireing from the fuse to the tail lamps, the insulation on the wires could be could be broken and shorting againt the bodywork.
If you cannot find the fault, the quickest solution is to rewire the faulty circuit and bypass the faulty wiring.
If you cannot DIY then you need an auto electrican to find the fault and fix the problem.
Apr 21, 2012 | Chevrolet 1500 Cars & Trucks
1998 cadillac deville instrument cluster lights don't work
Hello: Check the fuses in the fuse box under the hood, drivers side also check the fuses in the trunk fuse panel on the drivers side. If the tail light fuse is open that will keep the instrument lights out also.
Oct 08, 2011 | 1998 Cadillac DeVille
Looking for a fuse diagram for a 1992 ford ranger.
tail lights wont come on my 1992 ford ranger xlt but brake lights and back up lights work also instrument panel lights wont come on
Jan 15, 2010 | 1992 Ford Ranger
Buck Ford Econline Van 1998-2006 Stereo Radio Wiring Harness Logo
416 people viewed this question
Top Buck Car Audio & Video Experts
xxxxxx xxx
Libran Moreno
Gil Shultz
Are you a Buck Car Audio and Video Expert? Answer questions, earn points and help others
