Question about Maytag CWG3100A Gas Single Oven
Gas Maytag oven won't ignite
A power power surge caused my oven to ignite. How an I fix it?
  • 31 Answers
My oven would take almost 25 minutes to get to 125 degrees. i replaced the igniter for around 48 dollars about a year ago and have had no more problems. hope this helps. if you are any kind of handyman at all it is a do it yourself job.
Posted on Feb 21, 2009
Whirlpool gas range
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Jul 26, 2014 | Whirlpool Ovens
Gs773lxss0 will not light
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start/
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/18---/Oven-won-t-turn-on-
Oven Won Turn on http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Oct 21, 2013 | Whirlpool Ovens
Mod# xfg374lvq stove: Both the oven and the broiler will ignite, but only stay on for a few seconds. It does not try to reignite. Is this the control module?
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven sensor: works with the oven control board to regulate the oven temperature. If there is an oven temperature problem, this sensor might be defective. The sensor can be tested by using an ohm meter. As temperature rises, the resistance measurement also rises. The manufacturer of the oven sensor determines the correct resistance, Oven temperature problems can be caused by other things, but this is one of the common causes.
Beware on some models now most of these ovens they are electronic and they are integrated into the control itself
some different sensor ohm readings at room temp. approx 16 ohms at room temperature and at 350?F it is 29~33 ohms.
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start Oven Won Turn on
Oct 09, 2013 | Whirlpool Ovens
MGR5729ADH Ignitor gets hot. Gas won't come on
The problem with the oven not lighting believe it or not is going to be that the igniter is weak and not drawing the correct amount of power to allow the gas to flow.I know it would seem since the igniter comes on that it could not be the problem yet since it comes on to me a oven technician with 30 years experience the igniter is exactly what it is.
GENE
Sep 24, 2011 | Maytag Ovens
We have a Maytag gas oven and it takes close to 30 min just to preheat to 350 degrees, however the broil setting works great. Any help would be great...
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Aug 28, 2011 | Ovens
Stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
Gene...OldTech2332
Aug 22, 2011 | Maytag CWG3100A Gas Single Oven
Gas oven repair for Maytag Oven CWG3100AAE after a
More than like a surge has fried most of the electricals in your oven. Since you are dealing with a gas appliance I suggest be very careful. Even the tiniest gas leak could result in your residence blowing up, etc.
For this reason I recommend call your gas company, and have them come out and install a new one for you.
It's just not worth the risk.
Nov 19, 2017 | Maytag Ovens
Just replaced the igniter in my maytag gas oven. Before I replaced it all was fine but since the replacement igniter was installed oven stays on all the time. I have to unplug power so igniter will turn...
Your oven switch or control has failed. This is the only way power can get to the igniter. Sometimes this is the cause for the igniter failure like the previous one you had. Could have fried it out pretty quick.
Apr 09, 2010 | Ovens
The oven of maytag range mgr5775qdw poorly
The ignitors/burners need to be cleaned properly.
Build up of grease, dirt, rust, mineral deposits, etc can cause improper gas flow resulting in a delayed ignition. That causes a build up of gas and the delayed ignition ignites it all at once, and you have your WHOOMP mini explosion.
Sep 25, 2009 | Maytag Ovens
Oven wont come on, installed new igniter
Make sure there's power getting to your range, oven or cooktop. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve/coil assembly
Jun 22, 2009 | Whirlpool Ovens
Maytag CWG3100A Gas Single Oven Logo
794 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
