Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
AaaaaaaaaaaaAFTER TAKING PICTURES IN DOORS WHY DOES IT GET BLACK ON THE RIGHT SIDE SOME TIMES NOT ALL THE TIME?
  • jonathan53 May 11, 2010
    Are the pictures portrait aligned? Are you using a lens hood?
    If you're using the built in flash with a hood could be casting a shadow.
  • 30 Answers
Typically this is a problem with flash photography.
are you using flash?
the speed of exposure, the time that the film is exposed is controlled by two curtains that cover the film and prevent light from striking it. One curtain is across the film at the start, and springs open, then the second which was open, springs shut.
for 'long' exposures the first one opens time passes and then the second closes, but to achieve very short times, the second curtain starts to close before the first one has fully cleared the opening. so the edge of the second curtain can be traveling fractions of a second behind the first.
the result is that NOT ALL OF YOUR FILM is exposed to light at the same instant. If you have a flash go off during a fast exposure, only that portion of film that is exposes when the flash fires will get the proper amount of light, the rest of the film being blocked by a curtain. Most cameras are wired to fire the flash as soon as the first curtain is fully open and before the second starts to close. If you have a faster speed set in your camera by mistake, the second curtain has already started to close when the flash goes off. The black area on the right side is that portion of film that was already covered by that second curtain when the flash fired.
if you have the camera set correctly (typically at 1/60th or 1/100th sec) then maybe you should take the camera to a local camera store, and have the curtains timed...
Posted on Jan 28, 2010
How do I set time and date
To set the clock, have good batteries in. Slide the selector to Setup (middle setting).
Push the large right button marked MENU.
Push one of the right side buttons, above the word SHOT, these are the right > and left < buttons. Push repeatedly until you see
Set Mode
Set Clock
Set where the last Set should be outlined in dark. Now push the OK button which is the large left button.
Choose the field to update with the right side buttons > or <, once you have the one to update, use the left side up and down buttons to change the value shown until it is correct. Choose the next field with the right side < or >, update the value with the left side buttons. Only when you are completed with updating all of the date and time values, do you hit OK to set them all.
After this all pictures will have the correct time available. Though you have to choose in one of the other menus whether to show the timestamp on the picture. The picture will have the date and time associated with the file when you take the card out to view it later.
Jul 02, 2015 | Simmons 119422C ProHunter Trail Cam 6mp...
My 2006 F-150 drivers side control panel is dead & none of the electric windows, locks, mirrors or door sensor will work. I checked all the fuses & they are fine. The passenger door sensor &...
With the list you have, I would think broken ground wire in the rubber boot from the A-pillar to the door on the driver's side.
I have seen this one a few times ( not chronic but happens ).
It is a black wire in the door to a-pillar harness. SWAG at why the window worked when open part way, the wire touched at that one time, and pulled back apart again.
Example picture of a broken wire
Sep 19, 2011 | 2006 Ford F-150
Every time I turn on my Canon A540 Powershot I get the black date/time screen. The date/time is all zero (the photo properties default to 1 Jan 1980) and I have to either enter the date/time or press...
Inside the battery compartment, right beside the AA batteries, there's a tiny little door labeled CR1220 (see this picture). Pry the door open with your fingernail, remove the little button battery located there, and take this battery down to your local drugstore to buy a replacement camera clock battery. Remember, it's a "CR1220" battery. It should cost only about $4.
Dec 29, 2010 | Canon PowerShot A540 Digital Camera
Where can I find the fuel filter on a chevy silverado. Picture will be great
The fuel filter is located under the vehicle on the drivers side. Usually right behind the drivers door. Some times they can be covered with a black plastic housing. Sorry no pics
Nov 24, 2010 | Chevrolet Chevy Cars & Trucks
I am getting deve home sensor error on my samsung CLX-3175-FN, how do i fix it or diagnose it?
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Mar 08, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung clx-3160fn deve home sensor error
Mar 02, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung Colour Laser all in one CLX3160FN "Deve Home Sensor Error" need a fix
Oct 01, 2009 | Samsung CLX-3160 All-In-One Laser Printer
Taking pictures
Hallo
First, try to use different batteries. it can cause to long reaction times
Second, try to buy a faster memory card, it usually help for the time it takes to upload and see the pictures on the screen
about the blurry pictures
are you using M or a different mode?
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
Screen going black
We have the same problem...I thought you could change the bulb or lamp...but not finding out any info about it! HELP! This TV cost way too much to have problems this quickly.
Jul 27, 2008 | Samsung PPM42S3QX 42 in. HD-Ready LCD...
Picture covered with 1/2 black screen
Next time it does it instead of turning it on/off to correct it,try taping on the side just to see if it reacts if it does you will be looking at a loose conection in the horizontal drive circuit.Seek assistance from a technician to correct the problem.Right now it should no be expensive.
Oct 01, 2006 | Samsung LT-P326W 32 in. HD-Ready LCD...
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
85 people viewed this question
Top Minolta Photography Experts
Mark Schmit
Mark Schmit
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
