Question about GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black
My GE oven keeps beeping and won't stop. Panel shows F7. How to stop it?
  • 3 Answers
In order to save your sanity, you'll want to "reset" your oven. Turn off the breaker for the oven circuit for about 20 seconds and then bring it back to the ON position. If you're handy enough to make your own repairs on the oven then you'll want to go to "www.repairclinic.com" to find out what you need to do to troubleshoot your F-7 code.
Posted on Feb 20, 2009
Have a amanda oven that wont stop beepin evey 15 sec what to do
Posted on Sep 19, 2009
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
The f7 number keeps beeping on my GE profile range. i am assuming the oven is no longer working as nothing happens when i push the bake button. the most annoying problem is that f7 beeps all the time; it...
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)
you have a stuck button on the key pad you will need a new control board to fix this.
goto http://lartoday.com/order_parts.htm , enter your full model number and search for control
levi
Lebarchrigen Appliance Repair
Mt. Holly, NJ 08060
www.lartoday.com
Dec 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge oven JTP15 beeping and flashine F7 error
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Jun 17, 2009 | GE JTP15 Electric Single Oven
Double GE wall oven - F7 code
from repairclinic.com:
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
Oven emitted black smoke and F7 beeping on display
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Mar 30, 2009 | GE Profile JK915 Electric Single Oven
F7 beeping an cannot stop it... any solutions?
HI, if this error code cannot be canceled, this will confirm a touch pad issue. the membrane is damaged and, this will require you to replace the ERC.
Replacing the Electronic oven control will fix this issue.
Mar 29, 2009 | GE JKS05 Electric Single Oven
GE Profile Gas Range oven turns off
I just read that the electronic panel malfunctions due to rear burner use. Now, I know that mine gets REALLY HOT in between the back burners (where the heat exhaust for the oven is) whenever I bake/broil. I am guessing that it can cause the same malfunction fromt he oven, as with the backburners. Whenever I use both back burners, mine shows F7 E6, too. Unplugging it for the night or just waiting til the beeping stops and then clearing it works... until I cook again. I read that the replacement part for the control panel is about $300 and another $200, more or less, to install it! I think this is more like a recall or manufacturer's problem. I have read plenty of complaints and I think GE needs to make a call to fix them!!
May 12, 2008 | GE Profile Spectra JGBP79 Gas Kitchen...
F7 Error on the above range
There is a fix for the F7 error. Search for Powerman + GE + F7
Apr 27, 2008 | GE Profile JT910SASS Electric Single Oven
F7
No F7 in my tech sheet Could it be a F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad if you want to do it yourself let me know...
Aug 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile 30" Self-Cleaning Slide-In Electric Range - Black-on-Black Logo
4,291 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
