Question about Toshiba Audio Players & Recorders
I have a reconyx trail cam. and forgot my 4-digit pass-code to retrieve the pictures. Any suggestions?
3 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: forgot screen 4 digit pass code
Ipod Lock
You can unlock iPod in one of two ways:
1...Enter the combination on iPod using the same controls you used to set the combination. If you do not enter the correct combination, the digits onscreen flash red. When you enter the combination correctly, iPod will unlock and return you to the last viewed screen.
2...Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can’t unlock iPod using either of these methods, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Important: Apple representatives cannot unlock an iPod if you forget your combination.
If you can’t unlock your iPod and you don’t have access to the primary computer, your only option is to restore the iPod, which will erase all music and data.
Good Luck,
I hope this helps
Posted on Nov 11, 2009
Midwest-Tek
  • 864 Answers
SOURCE: forgot the 4 digit unlock code.
no you cannot bypass the password. But however you can reset the password by following these steps. If this does not work please let me know and i will instruct you from there. An you will be able to claim ownership of your ipod once again
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the solution. thanks and have a great day.
Posted on Aug 24, 2010
Is there a factory reset
Normally you have to send it in to Bushnell and have them do it for a fee but in the past I used the following to reset a similar Bushnell trail cam and it may work for you:
1. Turn camera on and wait for the password screen.
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail Sentry cams will not indicate a 5 digit mode on the screen, but it will show "-----".
3.Press enter to confirm 5 digit mode.
4. Enter the 5 digit code "66214, then press enter. *Note it will accept a 5th digit.*
5.Camera should display "PASS" and go into the operating mode.
From here you can program a new password from the setup mode.
Nov 08, 2014 | Bushnell Trail Sentry 11-9200 Digital...
How do I change the password
2. Press and hold the enter button until the camera switches to the 5 digit password mode. "Trail sentury cams will not indicate a 5 digit mode on the screen, but it will show "-----".
My tasco trail cam boots up with 4 dashes on display. Nothing else.
When you hit enter does it change the dashes to zeros? Default code is 0000
Apr 27, 2014 | Bushnell Trail Sentry 11-9200 Digital...
How do i know my access code to retrieve my messages?
If its a new account you might try using the last 4 digits of your phone number. If its something you have setup previously and forgot I would suggest customer service or tech support.
Jan 21, 2011 | Lands Phones
I got my Bushnell Trail Sentry Digital Trail Camera and the code does not work so what is another code.
the first time the camera is used the code should be 0000 unless previously changed,try removing and reinstalling the batteries,this hould start your set up again.
press and release the power button and wait for 4 H's,"HHHH" to appear,this may give you another chance to use 0000 or whatever you chose as your password.press enter after each digit,then press enter again.the indicator should display PASS.if it displays ERRO then it is the wrong password.there is a password recovery service provided by Bushnell at 1-800-423-3537 and press option 2,you will need to provide your serial number to the representative.
hope this helps.
Jan 09, 2011 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell Trail Sentry Camera- forgot password
Trail Scout and Trail Sentry camera re-programming procedure.
1) Turn unit on and wait for screen to prompt password
2) Press the enter button and hold until camera switches into 5-digit password mode _ _ _ _ _.
Trail sentry cameras will not indicate 5-digit mode on the screen, but will indicate _ _ _ _ instead of HHHH .
3) Press enter to confirm 5 digit mode (for trail scouts go to next procedure).
4) Enter 5-digit code 66214 and press enter button( trail sentry cameras will accept a 5th Digit after the 4th 0ne is entered in the _ _ _ _ screen.
5) Camera will now go into operating mode, and user can now program a new password from the setup mode
Oct 01, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Decode to reprogram new pass word
Try this:
Sep 30, 2009 | Bushnell Trail Sentry 11-9200 Digital...
Bushnell trailscout model 11-9900
forgot my pass number on my bushnell trail scout 119900 plese assist
Oct 17, 2008 | Bushnell Trail Scout 11-9830 Digital...
430 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
