No i need manual for precision ws 380 - Computers & Internet
  • 217 Answers
How many milligrams of oil does Karcher 15" Upright Vacuum CV 380 need
Precision measurement of lubricant is completely unnecessary. Simply apply a sufficient amount of lubricant to all parts to partially saturate all pivots and bearings without applying so much as to make a mess.
May 06, 2015 | Karcher 15" Upright Vacuum CV 380 15"-...
Why the card cage fan is working faster in dell precision 380 without getting slower?
Don't try to slow down the speed if you don't know the temperature from your processor or your motherboard. Look on the web for a monitor program to see if one of them is getting real warm Like above 60 degrees Celsius. Then your fan will work as hell.
If the computer is a bit older, perhaps the cooling paste, between the processor and the cooling body on the processor is dried. Only use the correct cooling past, and not anything else. Don't allow the processor to heat up above 65 degrees Celsius, because it won't live long after that.
If you do have a monitor program, you could slow down the fan, without any risk.
Jun 15, 2014 | Dell Precision 380 Workstation Pentium D...
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Mar 17, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
How to fix a yellow solid light on a motherboard for a dell precision 390
dell precision 390 pc booting problem what i do WebRepOverall ratingThis site has no rating(not enough votes)
Oct 24, 2011 | Dell Precision 380 P4 Dual Core 3 GHz...
I have a Dell Precision 380. When I plug it in the power light (on power switch) is amber and the 4 light comes on. Fans are running and can hear the hard drive spin up. Nothing on the screen. I have read...
Could be a bad capacitors. Open up the case and see if you have any bulging caps. The second thing I would try is to remove all the ram and reseat each ram stick. The 380 can be fickle about ram placement.
Apr 03, 2011 | Dell Precision 380 P4 Dual Core 3 GHz...
Del 380 with light codes 1 & 4. The bios starting bar freezes at 90%. I have desconected all the periferals cards and drives. Same result.
Hi! The diagnostic light that you are seeing refers to motherboard/system board failure. You might need to contact the manufacturer to have it replaced if the computer is still under warranty...hope this helps.
May 23, 2010 | Dell Precision 380 P4 Dual Core 3 GHz...
Dell Precision 380
So the 80GB drive is an IDE drive, right?
Different manufacturer's have different BIOS' so I can't say with certainty what you'll see in yours, but on my ASUS motherboards I have a one of three settings:
PATA
SATA
PATA+SATA
When I run both IDE and SATA drives I need to use the third setting. I sounds like you're shutting off the PATA when you enable the SATA so there's no drive from which to boot.
If I misunderstand your problem please let me know.
Dec 22, 2007 | Dell Precision 380 P4 Dual Core 3 GHz...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
