Question about Brother IntelliFAX 2800 Laser Fax
Switched to shaw digital phone service from mts. my ph # and my fax # are different numbers but when phone calls come in the fax picks it up instead of the phone.how do i change this?
    Genius:
  • 2,120 Answers
Call a cell phone from the fax machine to find out what the machine's number is.
Be warned, tho, fax machines will not work reliably on digital phone lines.
Posted on Mar 11, 2009
Hooking up fax to KX TG7871 Panasonic Phone
There is excellent support here on basic fax setups. You have what is known as "Distinctive Ringing Service". There are pros and cons to the various setups. I assume you recognize the rings and answer only when the ring for the landline talk comes on. The fax will pick up the faxes, and the answering machine will pick up the voice.
Need model number of your fax - google that!
Service manual for your phone.
http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
This link shows various configurations of setting up your phone/fax/answering machine or using an answering service.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c00059780#Dist_ring
Distinctive Ringing Service setup While it is not available everywhere, a distinctive ringing service can be purchased from most telephone companies. With this service, more than one phone number is assigned to the same phone line. Each phone number will ring differently. The main number will ring with a normal single ring and the additional number will ring with a distinctive ring pattern assigned by the phone company.
When a distinctive ringing service is used, set the Rings to Answer to 2 and then follow the steps below to set the distinctive ringing pattern:
  1. Press Setup , press 4 , and then press 1 to enter the Answer Ring Pattern setup of the Advanced Fax settings.
  2. Use the Right Arrow to scroll through the available settings. When the ring pattern assigned by the phone company displays (double or triple rings), press OK .
Mar 06, 2014 | Lands Phones
When calling from other ph. to magicjack ph long dist ?
And was this a surprise?
You get to pick a number when you sign up for MJ service. It's not a guarantee that you will get something in your own area code or city or within the free service area to your other phones.
When I got mine, I had to get Detroit dial tone. I got to switch to Toledo, but even that's long distance to me. Just remember, you're saving so much money LOL
Carl
Mar 04, 2010 | Lands Phones
I have a Cannon MX310 printer, fax , copier. I cannot receive faxes. Can it have something to do with the fact that I have digital phone service, what setting does it need to work.
You might try a DSL phone filter to eliminate extraneous noise on the digital line. My digital phone line had constant, repetitave clicking noise until I installed a DSL filter. Have you tried calling your fax number from a cell phone to see if there is noise on the line and or if the fax will pick up?
Oct 31, 2009 | Canon Office Equipment & Supplies
Need to set up phone/fax instead of just fax
I have a HP Officejet J6480 All-In-One and needed the answering machine and fax to be on at the same time.  I called the help line at HP and they said I needed another phone line into the home but I tried this and it worked.
First I got a different phone number for the fax machine - they do this for no charge at my phone company. This is not another physical line into the home - it is just another phone number with a different ring - it rings 2 fast rings for the fax machine instead of the phones regular one ring. I set the answering machine built into the phone to pick up after 4 rings and I set the fax machine to pick up on 2 rings. Be sure to set it so the fax pick up number of rings are less than the answering machine pick up number of rings.  It worked for me. Hope this works for you too.
Apr 24, 2009 | Brother MFC-260C All-In-One InkJet Printer
Lexmark X6170 Has a shared phone/fax line with different numbers
Open the Lexmark "Fax Printer Setup Utility". Click on the "Connection/Dialing" tab. In the "Interact with Phone Line" section, "Answer Incoming Calls:" should be set to "If fax tones are detected".
If this is turning out to be too unreliable for you, you will need to either manually receive incoming faxes (by changing the setting to "Manual"), or you will need to at least spring for a separate phone number with a distinctive ring for incoming faxes.
Apr 05, 2009 | Lexmark X6170 All-In-One InkJet Printer
When people call our home number sometimes the fax machine is reached instead of the home number. What would cause that? I called Quest and they said it was a problem with the fax and to call you. Our fax...
Make sure the fax machine is correctly set up for the ring pattern of its number. I suspect it's either not set or set for the wrong ring pattern, and is answering the phone before you do when people call. Once the fax machine is set for the proper ring pattern the problem should clear up.
You can download a copy of the manual here if you've misplaced yours. Just pick your product (fax machine) and model from the drop-down menus.
Mar 13, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
Ricoh 1013F Fax Line answering phone calls
Not quite sure the Ricoh has what is commonly none as a fax switch. This actually catches the call and looks for the fax tone from the sending fax to determine if it is a fax or not. The Ricoh can not determeine what number is dialing in. It only knows a call is incoming.
You can ourchase a fax switch online or Radio shack had them.
Mar 09, 2009 | Ricoh Aficio 1013F Copier
On the m9516 what is the fax switch on and off used for?
The Fax Switch
The Fax Switch feature allows you to have two telephone numbers on one incoming line.
There is one telephone number for the line and another telephone number for a Fax Switch peripheral (e.g. fax machine).
To use the Fax Switch, you must subscribe to your telephone company for Distinctive Ringing†. The telephone company will then provide you with an additional telephone number (for your Fax Switch peripheral) which will have a slightly different ring. The 9516 will use the two ring types to determine whether an incoming call is for the telephone or the peripheral. The peripheral should be set to answer after three or more rings.
Note: If Long Distance Ringing† is available in your area, long distance calls will be sent to the Fax Switch peripheral. Also, you cannot use the Fax Switch feature and the Special Greeting feature at the same time. The 9516 must be configured so the Fax Switch peripheral is connected to pins 3 and 4 of jack number 2. See Connecting an optional fax machine or modem on
page 4 for more information.
Note:
If you subscribe to your telephone company for Call Waiting services, your Fax Switch peripheral may lose data or get disconnected if someone calls while your fax is receiving data. We recommend that you do not subscribe to the Call Waiting service from your telephone company if you are using the Fax Switch feature.
Jan 30, 2009 | NorStar Meridian M9516 Phone w/ Digital...
Winfax Pick-up
Try looking at best buy for a fax switching device it can tell the difference between data and voice. I don't know how well they work but i have not used that particular program. I did find this though on another site http://www.windowsitlibrary.com/Content/238/15/1.html
You can have Microsoft Fax automatically answer every incoming call to your modem or, instead, you can manually choose which calls to answer. The quickest way to change this setting is to right-click on the fax icon on the Windows taskbar then choose Modem Properties to display the Fax Modem Properties dialog box . Another way to get to these properties is from within Exchange; choose Tools, Microsoft Fax Tools, Options, then switch to the Modem tab, select the modem, and click the Properties button.
So you have to change the settings in Exchange I assume
Jul 08, 2008 | Symantec WinFax Pro 10.0 for PC
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Brother IntelliFAX 2800 Laser Fax Logo
176 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
