Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
Ust changed the fuel pump on John Deere 6300 and will not start
Tractor will not start after replacing fuel pump that was located in tank.
    Problem Solver:
  • 8 Answers
Can you hear the pump run when you turn the switch on? If so, you have installed the pump correctly.
There could be an air lock...... there should be a handle somewhere for a manual pump you can loosen a fuel line connection and pump until the bubbles stop and all fuel comes out.
Posted on Feb 21, 2009
    President:
  • 1,627 Answers
Open the bleader screw on the filter housing until you get solid fuel with no air,the turnn off the key and closevthe screw.the tractor should start.If not you will need to "crack"ONE OR TWO OF THE INJECTORS AND CRANK THE ENGINE TILL IT TRIES TO START.Then on you next attempt it should go.
Posted on Oct 20, 2009
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
Carb trouble not enough gas
If your not getting enough fuel to the cylinders, start with the obvious from the fuel tank forward... 1- make sure the is fuel... Top up tank. 2-change fuel filter (with John Deere clear plastic filter) that way you can physically see the fuel in the filter. 3. Fuel pump, and hoses... Pull off the hose going to the carburetor from the fuel pump, so that it disconnected from the fuel pump side only.. Get a container of fuel put the hose pump hose in the container of fuel, get some to crank over the tractor and see if it starts / draws up the fuel out of the container... If the tractor starts you could have a faulty fuel pump, or fuel lines... Or the small hose connected to the crankcase could be disconnected.. 4. Open the bowl on the carb, see if there's fuel present, and if there's any debris, if so maybe theirs something blocking the fuel from the needle and seat, (also gentle move the needle and seat open and close to ensure the needle is not seized.
Nov 17, 2013 | John Deere 3010 4010 Pto Shaft 540
John deere la 105 is not getting gas to carburetor. changed pump and blew out lines
Take line off fuel filter and see if you fuel. Check the outlet in the tank and fuel cap vent.
Oct 22, 2013 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere tractor with a Kawasaki 20HP V-TWIN that will run on starter fluid, but will not start normaly, I replaced all the fuel related items on the engine, including rebuilding the carb,
recheck your jets also check the needle valve seat they swell up and stop fuel flow next replace the solenoid with a short bolt and try that they might sound as they are working but don't
Aug 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I have a john deere 6400 that wont start from cold even with a new battery it needs jump leads from another tractor and then still struggles the hazard warning light and the information light on the dash...
i had the same problem, it is most likely that your fuel lines are leaking and fuel pump in tank is weak
when the tractor sits for a while the fuel drains back into the tank, thus your injection pump has no fuel in it.i solved it by replacing all the lines and i added electric fuel pump on outside of tank and connected the power to key,when i start the tractor i turn key on for a minuet or so than start the engine ,it solved the problem.
john b
Nov 16, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
My John Deere X320 has gas fires up, but will not start running
Alot of the X300 series mowers were shipped out of factory with interlock modules that failed often and some were on a fix-as-fail program.Not sure if this is whats wrong with yours but if it was in our shop its the first thing that gets replaced depending on you serial number.Its located just under the front side of dash with a few wires going to it.
Oct 20, 2009 | John Deere 3010,3020 Tractor Basic...
John deere 445 with 22 hp kawasoki engine wont run take 1 plug out it runs dont mater what side stick finger in plug hole engine shuts off ,but wont start with both plugs in
Remove fuel cap to see if there is alot of fuel spraying back into tank.I have replaced ALOT of fuel pump hoses that have split between pump and sender clamp inside of tank.Lack of fuel pressure creates a very lean condition with the injected models.
Sep 03, 2009 | John Deere Garden
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
752 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
