Question about Dell Ethernet Card Network Adapter
Do I have an ethernet card?
I am trying to find out if my computer has an ethernet card. It's a Dell XPS 400. I was wondering if the Intel (R) PRO/1000 PL Network connection is the same as the ethernet card. I want to upgrade from dial-up to high-speed internet. I was told that I need to have an ethernet card.
    Novelist:
  • 155 Answers
Yes, Intel Pro/1000 is gigabit ethernet, which will do 100Mbps and 10Mbps too.
This will be compatable with your broadband requirements.
Posted on Feb 21, 2009
Xps 400 6.0 gb/s hard drive upgrade wont work
Did you initialize the drive in control panel, administrative tools, computer management, disk storage?
Mar 03, 2014 | Dell XPS 400 PC Desktop
Identify correct network card for dell xps 420
You can buy any network card and install it to your computer. All you need to figure out is what type you want to get,
PCI card or USB
Wired or Wireless
Nov 29, 2012 | Dell Ethernet Card Network Adapter
Where is the memory card slot on the Dell XPS 400?
What kind of memory card are you talking about?
If it's one of those cards from a camera, PDA, etc, it should be on the front of the computer, if you purchased that option.
The normal XPS 400 does not have a memory card reader.
Oct 25, 2010 | Dell XPS 400 PC Desktop
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
This is Dell Support >XPS 400 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
http://support.dell.com/support/edocs/systems/xps400/sm/techov.htm#wp1053398
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675156&CatId=200
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
http://support.dell.com/support/edocs/systems/xps400/sm/about.htm#wp1053567
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
My Dell XPS 420 restarts itself whenever i play games on it
You might need a new Graphics card and a 400 w power supply. also, try cleaning it (the fans and HS's
May 13, 2010 | Dell XPS 420 DESKTOP - Intel?® CoreTM2...
No color Red, Dell XPS 400, NVIDIA GeForce 7300 LE video card
Mike,
I would recommend for you to try different monitor, so that you can isolate the problem.
If same problem occur, try to plug in your video card into another PCI slot in your computer. Cleaning the gold fingers of the video card with a clean cotton cloth might help.
Use a blower to remove some dust on the PCI slot.
Or try inserting the video card in another computer. If you get the same problem on another computer, you need to replace the card.
Mar 07, 2010 | Nvidia GeForce 7300 LE 256MB PCI Express...
NO VIDEO COMES TO THE MONITER, THE MONITER WORKS WITH OTHER COMPUTERS, ICHANGED THE VIDEO CARD AND STILL NO RESULTS , ALSO THERE IS A LONG BEEPING NOISES THREE TO FOUR TIMES AS I TURN THE POWER BUTTON ON...
It sounds as if your on-board graphics has stopped working. If you have a graphics card to try installing it. That may solve your problem. If not you will have to contact Dell about a motherboard replacement. the last time I looked at a Dell XPS system you can't install a retail motherboard in it.
Nov 24, 2009 | Dell Dimension XPS 400 PC Desktop
Need to install PCI card in Dell xps 400, but can't remove back to get to slots. No tools for 2 little black screws what to use?
You shouldnt need to unsrew anything on the xps 400.. Everything the case opening and the pci card screws should also be a latch!
Nov 15, 2009 | Dell XPS 400 PC Desktop
Unable to connect ETHERNET
Try These Things: 1 Shut Down Computer, 2 Unplug Ethernet Cable From Modem, 3 RESET MODEM, 4 Plug Back in Ethernet Cable From Modem To Computer and 5 Power On Computer. That Should Help You.
Feb 11, 2009 | Dell XPS M1530 Laptop
Cannot connect to internet after storm.
More likely it's the ethernet card or your ISP, (Internet service provider). Do this. Open control panel, open system. Click the hardware tab. Than click device manager button. Scroll down to network connections. Click the + sign which will open the network. Do you see a yellow ! point?
If you do than you need to re-install the network driver software. Click the link below, it will take you to Dell's web site. Listed there will be all the drivers for your XPS 200.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=XPS/DIMENSION%20200/5150C&os=WW1&osl=en&catid=&impid=
Click the + sign next to Network. Download & install the
Intel - Driver. Also download & install the Intel - HTML file.
There is also a Intel - Diagnostics Utility that will check your network card. This file may already be installed on your PC.
How ever do not run the utility un-till you install the other two files. Once you know your network card is working than it's down to your ISP. That requires a phone call. If your network card fails
you can add a new PCI network card. I'll post a link to some below. If you feel you need a new cable buy what's called a CAT6 Rj45 cable to go from your modem to the PC.
Click the link for PCI network cards:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=875257&CatId=200
Cable Rj45 CAT6
http://www.tigerdirect.com/applications/SearchTools/search.asp?cat=748&keywords=Rj45%20CAT6&mnf=
Both of these you can get at a local store. Opening the link gives you a picture to go by.
If you have more questions just post back here.
Good luck & kind regards.
Mar 09, 2008 | Dell XPS 200 PC Desktop
Dell Ethernet Card Network Adapter Logo
287 people viewed this question
Alun Cox
