Question about PfaFF Tiptronic 2030
How to thread 2020 model triptonic
How to thread.
My stitching on Brother ls 2020 sewing machine is loose. How do I fix the problem
Without more description of the stitch symptoms, the only suggestion is that the tension is too loose. Whether it is the upper, bobbin, or both tensions, we cannot answer without more information.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Dec 31, 2016 | Brother Sewing Machines
Pfaff tiptronic 2020 locking up/cutting bobbin thread
try changing the needle
when sewing a project-- the needle & fabric & thread must be compatable
check to see if there is any burrs on the needle plate or on the bobbin case
always make sure every thread guide is used
make sure the bobbin is inserted correctly in the bobbin case
Mar 31, 2012 | Sewing Machines
How do i fix the tension on my pfaff tiptronic 2020
It sounds like you need to adjust the bobbin tension. There is a small screw on the bobbin case to tighten/loosen the thread's tension coming out of the case. Refer to the user manual on the procedure to set it.
Nov 28, 2011 | PfaFF Tiptronic 2040
After cleaning my LS-2020 sewing machine, it now won't make stitches even though bobbin is in and threaded right.
Please check that the needle is in the right way, flat shank to the back and all the way up into the housing. This would cause the stitches to not form.
Failing that, if it is not picking up the bottom thread, then the timing could be out and it would need to visit the shop.
May 21, 2011 | Sewing Machines
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
Threading the machine
what is the setting to hem
Feb 21, 2008 | PfaFF Tiptronic 2040
Sewing Machines Logo
157 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
