Question about Garmin nuvi 780 GPS
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
  • 1 more comment
  • alphajoker Mar 19, 2009
    same problem except now mine won't even power back up...anybody out there with a real fix. resetting doesn't work - it won't come on.
  • Anonymous Apr 02, 2009
    I have experienced the same problem. I found that, by holding the "on" button to the left for about 8 seconds, the unit will reboot. That doesn't help in traffic but it sure eats the need to remove the unit before restarting it.
  • samysub Apr 19, 2009
    it won't turn on just like that... i tried and when my phone its closer to it it shows the bluetooth is there..thats mess up..
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Posted on Jul 15, 2009
I had to deactivate bluetooth 3 continued times before showing "updating bluetooth firmware 0%". >Tools>Settings>Bluetooth. I have Garmin 780.
Posted on Jan 11, 2012
Garmin freezes up on the first screen (which says garmin).
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
Jan 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 650
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Feb 26, 2008 | Garmin GPSMAP 60CSx
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
Nuvi 265WT Manuals here.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
Nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Nuvi 660 + omnia
Hi, version 3.1 is supposed to help with disconnects. Please see this link:
http://www.gpspassion.com/FORUMSEN/topic.asp?TOPIC_ID=109459
However, Garmin released 3.4 which will include the changes in 3.1 and also makes the bluetooth compatible with more phones.
You need to go to www.garmin.com and download their webupdater and run it with your Nuvi connected to the PC with a USB cable. It will check (via the Internet) if you need a firmware upgrade. The latest firmware version for a Nuvi 660 is v4.7. There is a second menu after the main firmware option that allows you to select additional software. Select yes and check the bluetooth 3.4 box and the Chipset "G" box if it's shown.. The Chipset "G" is the upgrade for the receiver in the flip-up antenna. Let it download. When finished, select to safely remove the Nuvi. You can now unplug the USB cable. Your Nuvi will reboot and load in the new changes. Whatever you do, don't turn your nuvi off! Let it go and update. You will see it say "Loader", then "Loading Software" and you'll see a task bar that says "Updating Bluetooth Software" and "Updating GPS Software" (if required). Once you get to the main menu and there are no more texts coming up on the screen. Press the power button and turn your unit off and then back on again. Check the GPS and Bluetooth firmware versions in your Nuvi. It should be 3.0 for the GPS and 3.4 for the Bluetooth. Check the firmware version if you selected v4.7. You will have to re-pair your phone with your Nuvi as the update erases any previous set-up. Let me know how it went for you. If you have trouble with this, let me know. I can do it for you. I have done it many times. Please rate my solution if you found it helpful.
- Jim
SHARCNET-USA
Jan 06, 2009 | Garmin Nuvi 660 GPS Receiver
Garmani nuvi 710 freezes on "updating bluetooth firmware 0%" when turned on
first off all remove the battery and clean the area where the battery is inserted and also press the reset button after u insert the battery and ON the device.also chage the device properly before connecting it to the bluetooth option. this many a times happens due to the humidity problem or due to the over loaded data processing.
thanks.
Jan 04, 2009 | Garmin nuvi 780 GPS
Garmin nui 360
Please tell me what the version of bluetooth firmware is showing up in your unit. You can access this by pressing the wrench symbol, then the gear symbol, then "about". The latest bluetooth version is v3.4. If it shows up as 0.0, then you need to reflash the bluetooth firmware.
One note: Everytime you update the bluetooth firmware, it erases your pairing information with your phone, so you will have to re-pair your phone with your Nuvi.
Best wishes,
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Bluetooth enable
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enabling
Sep 01, 2007 | Garmin Nuvi 610 GPS Receiver
Garmin nuvi 780 GPS Logo
1,799 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
