Question about HP DeskJet 2600 InkJet Printer
Hp Deskject D2545-paper jams, and other stuff
Brand New printer. Setup O.K. and test print-cartridge alignment all O.K.
Printed a few pages, all O.K. Next day, constant printer jams but sheet not jammed. Printhead does not come to center when cover opened and no reason for jam to occur. Printerr is not suppose to function with cover open- it does. Followed all HP problem solving, no satisfactory results. Constant "no paper" blinking light with paper properly loaded. Printer pulls sheets through with 3 rapid jerks and pauses and three wrinkles on sheet. Suspect interface circuit board problem. Printer is useless as is. Reloaded all software, no fix. Have used HP DJ's for years, several different models---no problems. Conclusion is I have a piece of junk!!!!!!!!!!!!!!!!!
  • 2785 Answers
SOURCE: Continual problem with paper jam
try with other manufacturer's paper, you can try by reinstalling the drivers
if the problem persist then your printer needs to be serviced
Posted on May 31, 2008
  • 781 Answers
SOURCE: documents are printing slanted on page
It sounds like need some technical maintenance and at that point you have two options.. take it to a service center, or buy another printer (or if whithin warranty talk to HP about your problem, your attempts to fix it and possibly get it replaced). sounds like a component inside your printer may be either not working properly or there's something inside keeping the rolling componentes from keeping the page straight as it goes through your printer.
It does not sound like a driver problem...
btw.. did you mean carriage jam or cartridge jam??
if it was carriage:
if it is a cartridge error try check the following:
Posted on Dec 10, 2008
  • 400 Answers
SOURCE: Paper gets jammed every time after printing cca 1/3 of the page
Nothing just get it serviced .. they wont jam again.. it because of grec in your machine which have caught on alot of dust.. thank you .. I had same problem and fixed exactly the way i have told you..
Posted on Jun 25, 2009
SOURCE: HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Posted on Aug 31, 2009
  • 685 Answers
SOURCE: My HP 7210 is misfeeding paper and jams
Give this a try...
Posted on Nov 10, 2009
HP A636 will not print yellow; tricolor cartridge is new
  • Align the print cartridge.
The printer automatically aligns the print cartridge after a new one is installed. You can also align the print cartridge at other times to ensure optimal print quality. Indications that you need to align the print cartridge manually include borderless prints with white space
along an edge, colors not printing satisfactorily, or poor print quality.
To align the print cartridge from the printer
  1. Load a sheet of HP Advanced Photo Paper in the input tray.
  2. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  3. Touch Cartridge.
  4. Touch Align Cartridge and follow the prompts.
Clean the print cartridge automatically.
If the printed pages are missing lines or dots or contain ink streaks, the print cartridge might be low on ink or need to be cleaned.
CAUTION: Clean the print cartridge only when necessary.
Unnecessary cleaning wastes ink and shortens the life of the cartridge.
  • Clean the cartridge.
Follow these steps to clean the cartridge automatically:
To clean the print cartridge from the printer,
  1. Touch the Setup icon to display the Setup menu. For more information, see "Setup Menu" on page 16.
  2. Touch Cartridge.
  3. Touch Clean Cartridge and follow the prompts.
If the documents are still missing lines or dots after cleaning, replace the print cartridge.
Attaching User Manual (see page 59).
Feb 18, 2014 | HP Photosmart A636 Compact Photo Printer
HP PCS1402 keeps printing test sheet on start up
Have u recently changed ur ink cartridge ? If so the printer is printing an alignment page . Turn it off then on , so it prints the alignment page. load the alignment page on the scanner glass and press the "Scan" button to complete the alignment. Once the alignment has completed the alignment page will not be printed again until you change the next cartridge. See your user manual for details.
May 17, 2012 | HP PSC 2355 All-In-One InkJet Printer
My hp officejet 7410 printer which has been working fine for a year suddenly will not print. after putting in new cartridges it printed out an alignment page. But still will not print a normal page. ...
Click on the Setup button,
Scroll till you find Tools - Press OK
Scroll till you find Clean Cartridge - Press OK
It will print an alignment sheet. Align the printer
If this does not work - try the Align Printer Option from Tools of Setup menu again from Printer front panel.
Let me know if none of these work.
Jan 31, 2011 | HP OfficeJet 7410 All-In-One InkJet...
Changed printer cartridge now wont scan printed sheet!Thanks,DV
Every time you put a new cartridge, the printer does a test page. That is because it is aligning your cartridge. Now what you need to do is take that test page and put it in your scanner as indicated on the test page. Then press "scan" on your printer. The printer should then do a scanner alignment and you should be able to scan. If you do not have that test page, print another one. Go to start, settings, find printers and faxes and open it. You will see your printer. Right click on the printer and you will see a menu. Open Properties. Find General- there is a "print test page" button. Click on it.
Apr 04, 2010 | HP PSC 1410v All-in-One Printer
Alienment sheet prints every time I print a page.
just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
. It is necessary to after aligning the page it need to scan with the scanner. Otherwise it keeps pop up.
Hope this helps. Please rate my response.
Have a good day.
Have a nice day and do not forget to rate please...!
Mar 15, 2010 | HP PSC 1315 All-in-One Printer...
Every time i open the printer an alignment page is printed.How can i disable that??
it is alignment test page just put the printed alignment test page paper on scanner glass and press the scan button to complete the process. It is alignment process which is printer is doing for self testing after installing new cartridge. Just finish the process.
Feb 16, 2010 | HP Inkjet 1200dn Printer
Printer prints a test page every time it is turned on.
Hi everyone
After replacing the print cartridges 2 steps need to be done:
1. Wait for the test page to be printed out and
2. Put a page over the scanner glass and press scan button on your
Turn off the printer and turn it on again to see if the problem was
Ali Khan
Dec 19, 2008 | HP PSC 1350 All-In-One Thermal Printer
Not responding to PC instructions to print data
You need to load the PRINTED ALIGNMENT PAGE on the scanner glass, then press on "OK" button. It should start scanning the alignment page. That way, you are completing the PROCESS of ALIGNMENT.
Thank you so much.
Jul 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Ink Cartridge Alignment
On alignment sheet, do you see a line of yellow blocks?
And on next line do you see alternate block and yellow blocks?
(Without these, alignment fails)
If not, change the colour cartridge, re-print the page and repeat alignment.
Good luck...
May 26, 2008 | HP PSC 2110 All-In-One InkJet Printer
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
HP DeskJet 2600 InkJet Printer Logo
318 people viewed this question
Ben Johnson
