Question about Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator
My ice maker has stopped working, the trays are full of ice but not going through the cycle.
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
.,mhjdg
Posted on Sep 30, 2010
My ice maker cycles and stops with ice full light on with no ice made
If ice is in the tray it could be that the heating element designed to slightly melt the ice so it can be pushed out, is open and needs replacement. But you might find that the cost of element is more than a new icemaker. Be careful
Go to attached site for details. parts, prices, etc. Search Over 2 1 Million Appliance Parts
Aug 25, 2017 | Freezers
Ice maker does not make ice
there is sometimes an armature that raises when the ice tray is full.you can raise this arm is you want it to stop making ice.look said arm and lower down into on position.it will fold down into a spot near the full level of the ice tray.
Aug 20, 2014 | Refrigerators
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
The ice make stopped working. There is ice in the water feed tube. The ice maker is full of ice, but it is not dispensing. Ice in the storage bin was frozen together into blocks.
The icemaker in it's operation hits a microswitch to turn on a warmer in the aluminum tray that aids in extracting the ice by the rotating vanes. It may be that that part of your icemaker has failed.
Try this for a solution first. Remove all of the ice from the bin. Using a hair dryer, melt the ice in the tray and the fill tube. Be sure to warm all of the switches behind the plastic front cap in case those switches are frozen. Let the ice maker fill again and see if you have made ice. Often splashed water will freeze the rotating vanes and will not let the ice maker rotate through it's complete cycle.
Mar 08, 2011 | KitchenAid Refrigerators
AMANA FRIDGE SCD23VBW, NEW ICE MAKER WON'T CYCLE
repairs should be performed by an authorized repair technician. D7824706Q complete ice maker should never be advanced manually. the ice maker arm should be in the down position in order to advance. once the inner thermal switch has been satisfied the ice maker motor should advance. the ice maker is damaged and will need to be replaced by the proper ice maker.
Jun 04, 2017 | Refrigerators
Ice Maker water keeps running
Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Polar Ice Maker Portable
there is a little sensor inside on the top right, it is a little wire if there is anything on it it will not work, i took at small pair of pliers and gently cleaned it
Jun 21, 2008 | Polar PIM15W Ice Cream Maker
Kenmore Elite - 106.55606400 - Ice Maker is not working
This is the replacement for the old one they stopped making the 260w
Apr 04, 2008 | Haier HRT02WNC Compact Refrigerator
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 52632 / 52634 / 52639 Side by Side Refrigerator Logo
87 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
